- Mar 27, 2009
Because it's a lockback, and frankly the principle of the backlock seems most sound of all folding knives to me. With overstrikes and spine whacks, longitudinal pressure is directed where the knife is strongest, basically two steel hooks pulling on each other, stopped by a metal pin anchored in the frame. The more force is exerted, the stronger the hooks grab into each other.Just curious, but why do you think the Manix 1 is stronger than the Manix 2? Because it makes a louder metal on metal clunk when it opens than the II? Just an assumption?
During chopping, force is directed into the locking lever, which basically can't go anywhere as long as integrity is maintained (thru its pivot). The worst that can happen (and does happen) is it creates vertical blade play.
This principle is maintained in the Tri-Ad lock, but with the added advantage that pressure against the blade (chopping) is now distributed into the frame via the stop pin, instead of the locking lever. This, combined with the shape of the tang and the locking lever forms an auto-adjust mechanism, which (in theory) should eliminate blade play for a long time.
Well you said it. People want change. They get Obama. They get the CBBL. It's definitely change. Just not necessarily better.Spyderco usually only discontinues a knife because of poor sales or because enough people ask for a change.
Yep, better than any other brand I know.People ask for good slicers and full flat grinds so they make them.
Exactly. Not necessarily make an objectively better knife.They do what people want and what sells.
I can only speak for myself here, I am not blaming Spyderco for anything. To me, the Manix II was never a hard use knife, clearly (to me) it's not designed as such.Either way, the change was brought about because of the consumer so blaming Spyderco seems silly.
I'm sure they test them. I am curious exactly how the Manix II was tested, especially considering your next point:Spyderco also tests all their designs and I'm sure has broke many times more knives than everyone posting in this thread combined. I don't know why you would think they would put out a knife that consistently falls apart when they know it would result in a ton of warranty claims and bad press.
I am sincerely interested in finding out what the tests are made up of, and what the ratings indicate. I also wonder how a CS AL would fare in their tests (as far as reliability and toughness are concerned).They are one of the few companies that actually test their knives and give them ratings and the CBBL gets their highest rating.
Give people a bit more credit. Even Cold Steel is not hated as much here as they were only a short 6 months ago. There may be good reasons for the failure, and (again, just speaking for myself) this would not sway me either way if I was about to buy the knife. I already did, and I'm not worried or disappointed.In the end it probably doesn't matter much what happens. A new video of a Manix II passing this test with flying colors won't negate this video where it broke (with a loose pivot) in the eyes of the doubters.
I don't give the die-hard Spyderco fans much credit in this regard. NOTHING is going to sway them. Ever. And I guess that's fine too, it just makes discussing sensitive issues like these with them pointless.And the fans aren't going to let one video of a lock failure with an obvious problem going into it sway their confidence of the lock until there is more proof and a larger sample size than 1.
In general you could argue that one test of one knife does not constitute proof, and formally speaking you'd be correct. But Jim's video's were done fairly, I think we all agree on that. There was no malice, and no bias that we could see.I would have no problem accepting the CBBL is not a hard use lock if I saw some more evidence that shows it fails consistently without a loose pivot. But I'm not going to say it is weak when it failed so easily and had an obvious issue at the beginning of the test.
More importantly, this issue is only as important to you as you choose to make it, same goes for all of us. If you'd never seen this video, you'd still be perfectly happy with your Manix (not sure you own one, just guessing
It would be different if Spyderco made the same type of claims that Cold Steel does. They don't. They're not at all interested. And I'm fine with that, I like all my Spyderco's as much as my Cold Steels (one of them even more
Peace!
