Are you going to do videos of this with the Strider & ZT?You guys need to do some overstrikes really if you really want to test the lock, spine whacks are nothing compared to those.
They put a lot more stress on the lock than the spine whacks do.
I do both in all my current testing.![]()
Interesting "hard use test." Can you send in the knife? Please send the knife in without any further adjustments? Thx much –Eric
I think the Manix II is just too fancy. It's too complicated, too many things can go wrong. I like mine a lot, but it (like most Spyderco's) looks and feels fragile compared to most CS knives, as well as many others. That is not a criticism per se, because I am convinced Spyderco favours these designs, and could easily make very tough folders if they chose to.WI am curious as to why it failed, looking at mine it doesnt look possible for that to happen without something major breaking inside.
Most Spyderco fans have suggested this. I guess it's possible that of all the Manixes Ankerson could have tested, THIS one had to be defective.Or maybe a defective spring with not enough pressure.
I do too. The 1 quite a bit more than the 2.Still love my manix.
It's not about what anyone says. What matters is, do you accept the results of the tests, and if so, what are the implications (if any) for you and other Manix II users?But I did buy it to use it, and not worry about it taking off my fingers for any reason. Regardless of what anyone says, it shouldnt fail with that light of use.
Interesting "hard use test." Can you send in the knife? Please send the knife in without any further adjustments? Thx much Eric
Fair enough.I accept the test. The implication is only to confirm that I will continue to use my folders as I always have - treating them all as if they were slipjoints. If I need an impact tool, I'll find something else.
Agreed. Thin sharp tips are great for some purposes, and suck for others. I tried to dig a splinter out of my fingertip with an XM-18. Couldn't do it. Any of my Spyderco's could have, it was the Manix I in this case. So I have no issue with fragile (relatively) tips, in fact they're indispensable sometimes.In my mind the tip breakage is a totally different issue. Tips, and the rest of the blade, are what they are. You buy what you need. With a little variation for steel and heat treatment and grind, thinner means weaker. It isn't like different lock designs, where you can't really reach conclusions based on solely on physical dimensions and design.
I pretty well have always accepted my ZT 0300 is probably stronger than any other folder I own. That really never made me think it was better, just different and great for some tasks and not so great at others.
