Perrin Streat Beat has an MSRP of $250. I have one and I think it's worth the street price. It's made in Japan. At a higher cost and a less appealing design, I won't get a Bushcraft.
Usually what happens is that the 'buzz' around a new knife keeps its price point high until activity drops off. Consider the Kumo which started at $200 and eventually made its way down to $100 before disappearing. Similar trends are happening with the daywalker/woodswalker/forester choppers that are now starting to fall in price. It will be released at a high price point and then later drop to its actual value.
The question is whether your will power will keep you from buying this puppy just so you can be the first to post it up on bladeforms with a review ------ a laughable comment, but you know it is bloody true!
Here is what you do. Put some elbow grease and polish up the blade through a series of grits to about 800 grit, removing all the bigger scratches. Then force a patina on it with vinegar or mustard. You won't run into rust problems after that. What little bits of corrosion sets on the edge will be worn off with use. Oh yeah - use the knife. That helps.
