I like some.
The stuff Bark River uses and also the stuff Fallkniven uses is great.
CPM 154 is suppose to be really good stuff, not like those cheap stainless stuff. Plus with Crucible out the picture, CPM 154 is going to be hard to come by.
I've read that CPM154 will be back on the market soon, likely in January. It's going to be made under license by Niagra Specialty Metals.
Maybe someone should build indentical knives out of the best stainless and say O-1 and then test them head to head. That would be interesting!
It's all about the heat treat
I'm a fan of Rat Cutlery and their 1095 for my outdoor blades, excellent stuff. However, there are also very well done SS blades from many companies. A quality company will generally make a quality product, and of course, you get what you pay for!
I have to agree with most of what baldtaco said.
There is so much BS hype in the knife market, and it's an artificially created market at that. The knife makers and companies try to make each knife buyer think they have the modern Excaliber in their hot little hands, and people try to make more of it than there is. It's a hunk of steel thats tool, get over it. Most of the modern stainless is darn good stuff. Even the stuff of 30 years ago was good.
In 1967 I went over on my tour in Vietnam. The issue knife was the Camillus MK2, or what people called a Ka-bar no matter who made it. At the same time on every army base, Buck was the big item at the PX. If you wanted something better than the issue knife, guys bought a Buck. Everyone, I mean everyone, had a 110 on thier belt. Going out in the field, one saw a heck of a lot of Buck 119 specials on belts. Young GI's being young GI's, all the knives saw heavy use bordering on abuse. I don't recall seeing a Buck special breaking, But I saw a couple of the Camillus MK2's break. So much for 1960's carbon vs stainless. They were used a lot for busting the metal bands off ammo and other boxes.
And speaking of the Buck 110, they have to be one of the most abused knives on earth. Every construction worker, oil field roughneck, farmer and others making a living outdoors in the 60's and 70's used the 110, and it developed a repuation for an entire knife company to become an icon for a quality knife. This was not because they didn't work well. One could make a good arguement that Buck, raised the bar for all the factory makes of knives. If you go over to scandinavia, the huge bulk of Mora's produced are stainless steel, and I don't see many brokeen mora's. I have seen them pounded into trees, pushed on, levered on, and pounded on while battoning. The mora's seem to have their cult following as well. I'm sure this is not because they are not good knives.
Plain and simple, with modern steels, there is not a lot of differnce anymore. BUT... the stainless steels are harder and more expensive to make. Stainless steel is a PITA to work with. I spent 30 years as a machinist, and I turned enough stainless parts on a Harding lathe, and did enough parts on a Bridgeport mill to tell you that stainless can eat end mills and other tools. It's gummy, hard, and you need to run a ton of coolent on it. It will eat up three times the sanding belts.
In the early 1960's when Smith and Wesson came out with the first stainless steel revolver, the model 60, I recall seeing an article about it. The S&W personel said that gang drilling a normal cyclinder, the bits would last 50 to 60 cylinders. Making a model 60 cyclinder they only got 10 to 12 cylinders out a gang of bits. Stainless steel can work harden on you, and gall the tooling.
Carbon steel is way easier for a maker to produce. Pure and simple. If I were a knifemaker today, I'd try to hype the hell out of my 1095 blades, because I don't want to screw around with that stainless. Stainless also has a far narrower window for heat treat. With carbon you can do it with a torch and get it halfway right and still end up with a good knife. Pump that anti stainless hype out there. Add in the old BS from the 1950's that stainless is no good, spouted by all the old timers, and there you have it.
It all comes down to a artificially created steel snobbery.
The knife makers get to make their stuff out of a material thats cheaper and easier to deal with, and charge you more for it. It's a win/win for them.
The truth is only about 1 in 100 people will ever be able to really tell the difference, if that many. Even then it's goiing to be a close thing.
And yet the edge is more likely to chip than on many carbon steels.Yet I can think of a company that is outing these at more than the price of a similar sized tool expertly heat treated in laminated VG-10.
There are also many (japanese) craftmen that can deliver handmade water quenched laminated blades for the price of some factory made ones.
