Exactly, same here.I've always preferred the 25'. I never took to the Fat Max because I don't like the shape/feel of it. The longer tapes seem to develop issues. The new 25's seem to have thinner gauge steel in the blade than they used to back in the 80's and 90's.
And I don't care about the box to write in because I use these stick-on laminate scratch pads. They work great!
https://www.amazon.com/Carpenters-Scratch-Pad-Tape/dp/B00309MYAW
No, sorry. I meant the frogs, cap irons, chipbreakers, blades, or the match plane in the back. I accidentally busted one of the parts that holds the irons off the body on it.
I like that old torpedo level. Looks pretty solid and the vial covers are cool. I also like the square shape which allows you to draw a line all the way into a corner. Torpedo shaped levels don't allow that.
Stanley No 71 1/2 router plane:
IDK if the 71 1/2 is less common than the 71, but for what ever reason when I decided to get one it was harder to find.I wanted the closed throat b/c it has more sole to contact narrow stock. YMMV
Some more here:
http://www.supertool.com/StanleyBG/stan10.htm
Bob
Alas, that is the only one.Did you get the other two irons with it?
Bob
The iron looks like a pretty simple thing to forge. If you really wanted others sizes you could have them made.
