SteelDriver said:
I give him the benefit of the doubt that the HRC testing he does is an acceptable measure of HT consistency.
It measures one aspect of heat treating, the required hardness, it doesn't check for the vast array of properties that can effect performance and are not caught by hardness checks which is why makers like Phil Wilson and the higher end production companies do lots of others tests.
These then insure a much higher guarantee on performance than a HRC check, though that of course is much better than nothing and would catch a lot of the lemons that pass through and get into the hands of the customer.
As for letting makers decide standards of testing on their products, that is really not logical. There is a reason why independent bodies do this kind of thing. Anyone who relied simply on HRC tests for QC is only testing a small fraction of performance.
One of the main reasons why destructive testing isn't done is simply cost. You have to fully grind and heat treat a blade, which costs time and money, and then be willing to throw all that away, and keep doing it over and over. You can't simply take a blank, because you have to know how the grind effects the flex, the strength and the edge impacts.
Being specific, I have broken several blades which passed HRC checks and failed due to geometry issues, or steel aggregates. These issues would be much reduced with small sample destructive testing.
SteelDriver said:
Isn't it reasonable that Striders would perform these performance tests similarly well? Given the same geometry of S30V, would you expect all S30V heat treaters to be able to consistently produce knives that duplicate this level of performance?
Yes, those that aim for it with similar heat treating goals.
Since you are not interested in reviewing a Strider...
I am not interested in reviewing a Strider because the performance statements from the manufacturer dictate such a conclusion as stated in the above, plus feedback from other users and my own expereince with their other knives and collaborations. For similar reasons I am not interested in a lot of knives on the market.
I only have so much time, obviously I spend it on the blades from makers who make statements of performance which interest me and guarantee them, not those that do the opposite, and I don't even have enough time or money to look at all the blades I would want to, there are too many to name.
This isn't a hard concept. I have used ATS-34 by Bos, I have used S30V from custom and production manufacturers, none of it I would call tough or flexible. Now I am not going to keep investigating this trying to prove to a manufacturer that the performance is actually better than they are promoting when I have never seen anything to indicate otherwise.
If a manufacturer wants to openly state that you can expect significantly higher performance than I have described in the above and *guarantee it*, then ok then I would be interested. This means they state it is significantly tougher than the custom and production S30V I have used and guarantee it.
As for the Raven test, I discussed that here publically when Rob was alive as it was being used to promote the extreme toughness of S30V for awhile, there are a couple of problems with it which are *GENERAL* issues I have noted elsewhere, including comments on past reviews I have done in the updates :
1) bending a knife in wood is problematic for flex tests because the wood bends and thus how much of the bend is the wood and how much is the knife. I bent a Voyager to 90 degrees in wood, does this mean it is flexible - it would not come near this in a vice. You could easily bend any knife to 90 if the wood was soft enough.
2) impact work and chopping depends on effort and method, I have chopped 3.5" nails with a Deerhunter (very slim knife), by cutting gently and taking care for the impacts to be perpendicular, get sloppy or fast and the edge buckles and loses huge chips. You need to use other knives for benchmarks and have some way to measure impact strength such as number of hits to cut the tension bar and amount of concrete removed on the chopping.
For example, during the WB concrete chopping when I went light the WB did better than Kirk's bowie because it was harder and had a thicker edge, but when the force was increased the edge started to fracture while Kirk's kept indenting and thus at high impacts the bowie did better. If I just used the WB I could have stopped after the initial work and the picture of performance would have been very different.
If the arguement was that this was showing the ability of S30V, the advancement that this steel allowed, then use an ATS-34 Raven along side the S30V one and show how the performance had improved. Without a benchmark it is difficult to judge the performance. I cut tension bar with a few knives after this came out, I could break some stainless blades if I hit them fast, or cut it if I went slow. With some really tough blades I could go all out and cut it in under 6 hits with no problems.
You need references, some way to have perspective. Just like if I said I cut a 2x4 in 20 seconds with a 10" bowie, is this impressive or not. Well it depends on the wood, it is pretty sad if it is fresh clear pine, lightning fast if it is a piece of ironwood.
-Cliff
