SteelDriver said:Chiro75,
Paul has a brochure with details:
http://www.buckknives.com/downloads/Paul_Bos_Brochure.pdf
Where/how did you get the up-to-dated Paul Bos brochure?
I had the last one only.
Thanks
There are lots of very fragile CPM steels, and yes they even contain vanadium. I have broken CPM-S30V by impact and bending, it isn't significantly tougher impact wise or more ductile than ATS-34. Nor in fact has any maker made such a comparison and guaranteed such performance.conan said:It is a fact that the CPM process itself improves the mechanical properties of steel, especially toughness.
R.W.Clark said:Just another moronic statement from Cliff the resident windbag.
That sentence says it all!R.W.Clark said:Cliff may play games with his testing and reviews but we do not play games with our knives because, unlike anything that Cliff does, lives depend on our work.
Such as?tknife said:... personal attacks on Mick Strider.
Yes, and show how such data supports the statement that S30V is significantly tougher and more ductile than ATS-34. Now make a public statement that you guarantee such performance in your knives, specifically stating the level of inferiority in the other blades I mentioned.R.W.Clark said:So you want me to bring out all the Charpy and Catra charts from all the differant test facilities, all the knife companies that have run their own tests, all the makers such as Hossom, Strider, Simonich, Mayo, Carson, Rinaldi, myself etal who have done their own cutting tests?
If he didn't he would not have anything to say. As a note of interest, how long do you think I would be permitted to post on Bladeforums if I responded to such posts with similar.brownshoe said:RW Clark. As a moderator, you should really stay off the personal attacks.
brownshoe said:RW Clark. As a moderator, you should really stay off the personal attacks, or you should resign as moderator. Calling Mr. Stamp a fraud and a moron is certainly beyond the rules of decorum for this forum. Shame on you. If you don't like Mr. Stamp, ignore him. If you have specific factual comments to refute him, do so, but do it as a gentleman not as a cad.
As a word of warning, since you used your own name, this is a public forum, and you're comments are in writing, you could also be sued for libel.
Cliff Stamp said:If he didn't he would not have anything to say.
It isn't an attack to point out performance issues, or lack thereof, and I have talked with people who work for and with Crucible, both in email and on the forum with similar issues.tknife said:If there is a problem with S30V, shouldn't you be attacking Crucible, not just the makers who use the steel?
Cliff Stamp said:It isn't an attack to point out performance issues, or lack thereof, and I have said the same things to crucible, I have talked with people who work for and with them, both in email and on the forum.
-Cliff
What other tests specifically? How do you know Paul Bos doesn't do these other tests? Do you know the full testing and QC regimen for Phil Wilson, Paul Bos, and "the higher end production companies"?Cliff Stamp said:It measures one aspect of heat treating, the required hardness, it doesn't check for the vast array of properties that can effect performance and are not caught by hardness checks which is why makers like Phil Wilson and the higher end production companies do lots of others tests.
These then insure a much higher guarantee on performance than a HRC check, though that of course is much better than nothing and would catch a lot of the lemons that pass through and get into the hands of the customer.
You're missing my point. Once a reproducible, quality HT schedule has been established (with plenty of testing), what is the point of doing destruction tests, etc. when HRC is an acceptable measure of consistency (where did I say performance)? In a large HT operation once oven temps, quench rates, etc. are all dialed in and within tolerances, all you really need is to spot check the HT in each batch. Some heat treaters go further and check the HRC of every piece, and I imagine some include scrap steel to break afterwards to examine grain.As for letting makers decide standards of testing on their products, that is really not logical. There is a reason why independent bodies do this kind of thing. Anyone who relied simply on HRC tests for QC is only testing a small fraction of performance.
You never pointed out these *GENERAL* issues in that thread, because Rob was clear about what he did. As for bending the knife, Rob provided plenty of detail:As for the Raven test, I discussed that here publically when Rob was alive as it was being used to promote the extreme toughness of S30V for awhile, there are a couple of problems with it which are *GENERAL* issues I have noted elsewhere, including comments on past reviews I have done in the updates :
1) bending a knife in wood is problematic for flex tests because the wood bends and thus how much of the bend is the wood and how much is the knife. I bent a Voyager to 90 degrees in wood, does this mean it is flexible - it would not come near this in a vice. You could easily bend any knife to 90 if the wood was soft enough.
If the arguement was that this was showing the ability of S30V, the advancement that this steel allowed, then use an ATS-34 Raven along side the S30V one and show how the performance had improved. Without a benchmark it is difficult to judge the performance.
This was not soft wood, and Rob compares it to carbon steel blades, not ATS-34. He provided references. You perform the same kind of tests in your reviews. If you don't accept Rob's tests, why should anyone accept yours?Rob Simonich said:For the stump thing, I started by driving the tip in the top of the hardwood stump about and inch and pulling it out sideways, then 1 1/2" then 2" etc till at about 3 inches I couldnt pry it out sideways. The blade took about a 2 degree set. Ill try to get a picture of it that shows the bent portion.
I was braced and pulling as hard as my romping stomping 145 pounds of pure raw muscle and sinew could muster! I dont know how many degrees of flex I was pulling the knife, but I feel it was one of the stiffest knives I had ever done that with. I have done that with carbon steel blades of similar geometry and they flex easier.
Again, Rob provides details of his impact work, in reply to your inquiry as a matter of fact:2) impact work and chopping depends on effort and method, I have chopped 3.5" nails with a Deerhunter (very slim knife), by cutting gently and taking care for the impacts to be perpendicular, get sloppy or fast and the edge buckles and loses huge chips. You need to use other knives for benchmarks and have some way to measure impact strength such as number of hits to cut the tension bar and amount of concrete removed on the chopping.
I cut tension bar with a few knives after this came out, I could break some stainless blades if I hit them fast, or cut it if I went slow. With some really tough blades I could go all out and cut it in under 6 hits with no problems.
Rob was clearly not holding back when he hammered the Raven through that tension bar. He does not give specifics on the concrete chopping, but it is reasonable to assume that he did not go light and easy with that test either.Rob Simonich said:Cliff, I used full power swings with a 2 pound hammer to cut the bar, took about 10 swings.
The reason I cut the steel bar was, well, to see if the knife would do it! The knife wasnt damaged that I or Jerry Fisk could see hammering it through the chain link fence, and the steel was laying there sowhy not. It was my intention to take the knife to destruction anyway. The bar was laying flat on the stump, nothing underneath it. I think this is about as abusive as you can be with a knife, you have steel on the bottom, hardened steel in the middle, and hardened steel doing the hammering. The shockwaves traveling through the middle piece, (knife) have to be horrendous.
Ironically, you profess the need for references yet you reject Rob's review, which is full of them. Rob Simonich, Terrill Hoffman, and Jerry Fisk (among others) witnessed these tests in person. Were these individuals deceived somehow, or unimpressed with the work (as you are)? How many people have seen your testing? You reference your own reviews often, yet how do any of us know that what you describe as soft, clear wood isn't hard and knotty? How do we know how much force you use to chop concrete, or that it is concrete and not cinder block? Rob clearly demonstrated what S30V in a 7" combat knife geometry can do. It seems far different than the "brittle" ATS-34 and S30V you have used. The guarantee is solid as well:You need references, some way to have perspective. Just like if I said I cut a 2x4 in 20 seconds with a 10" bowie, is this impressive or not. Well it depends on the wood, it is pretty sad if it is fresh clear pine, lightning fast if it is a piece of ironwood.
But then again, you're only interested in guaranteed superior performance. I suppose you'll only be testing knives from a single company, then. :yawn:Simonich Knives LLC Guarantee
All Simonich Knives come with an Unconditional Lifetime Guarantee.
Simonich Knives LLC reserves the right to repair, replace or refund the purchase price at out discretion.
I agree, I cannot say that you have personally attacked him in every thread. And there is no way I would go through and try and pick out quotes of this. But, threads that mention Strider seem to bring you in railing against their knives. Can you deny that by slighting the product he makes at every chance you get is not really an attack? Everyone on this forum knows that you are not a Strider fan, maybe it can just be left at that?Cliff Stamp said:It isn't an attack to point out performance issues, or lack thereof, and I have talked with people who work for and with Crucible, both in email and on the forum with similar issues.
How about defending your statements, point out where I attacked Mick on the forums. You said I do it all the time in any thread which mentions Strider so you should have no problem turning up quotes.
-Cliff
