There is a flip side to that argument though isn't there?
You can't chip your edge if you have NO edge
Ultimate durability is usually just thick geometry mixed with low alloy, with a low hardness heat treatment.
The minute any serious cutting is being done with a knife designed to handle hardcore impact, prying and chiseling, the edge rolls and blunts and you have to stop and sharpen it every 5 seconds
Also, no use in putting a killer edge on that kind of stuff. It doesn't really want to take shape or release the burr, also it can't hold a crisp polished edge. Just goes smooth with very little use.
If you put that kind of steel in a slicer geometry (.100 stock, flat grind to 0.005"behind a 15dps edge) it's garbage and may even have some deformation behind the edge from basic cutting since it lacks the strength needed to hold it's shape.
The malleablity is perfect for impact energy and not breaking and relying on geometry thickness for strength/support.
So why not slice with a thicker knife? Well, you'll shoot a carrot across the room trying to slice with a thick boi. Generally, Thickness compromises cutting performance and quality for durability.
So those of use that can sharpen and not use our knives like hammers appreciate the harder steel since it supports geometries made to "cut" not bludgeon, chisel, scrap and pry.
I'm all for steels on the durable spectrum AND the cutting performance spectrum just have to point out that everything is a compromise. it seems people are vehemently in one camp or the other and refuse to see the benefits of either side and how the synergy works.
Just an opinion, not gospel so don't freak out
Personally, in a real world not made of cardboard and clean rope and dead vertical cuts, I find most supersteels brittle and lacking, especially in stainless. 3V seems to be the exception.
But yet blades get ever thinner, even while the supersteels are not advertised as springs. Not even 3V....
If all you want is the world's most expensive box knife, many makers and steels have you well covered.
But when it comes to puncturing and opening a tin can, light prying under a stripped fastener head where only a knife edge will fit, hard stabs hitting unpredictable materials and objects...
A lot of the old fashioned steels look pretty good, especially when wanting a stainless blade....
I remain unimpressed, in general, as gains often taken away by making tactical/military chef knives....and the steels not rated for flexing, at all....I would rather have a martempered 80CrV2 blade for most of those combat cook knives ever so baby talk "slicey" as demanded by a market of office workers whose main use is in the kitchen at home....
