Also, looking at the Quench K data sheet, is says the oil CAN be used up to 180°F, but the 7-9 second nickel ball speed reading was taken at room temp of 80°F. I would try the oil at room temp, because that is what Houghton says is the 7-9 second range. Going above or below that temp may screw up the nickel ball speed.
Pretty amazing that the 1095 hardens in the oil, but the W2 needs brine. They are essentially identical steels, they both get the same HT and quench medium.
When you get the P50, you will note that it also CAN be used in the 130°F range, but the best quench temp for P50 is actually room temp, maybe slightly above. I use the same W2, 1/8" thick, normalized and cycled, P50 quench, 66+ HRC post quench, every time. Others have had serious serious issues with this W2. 1900°F normalizing temp was the only thing that would get it to harden properly. Keep that in mind, Jeff. This W2 can have issues.
