Jerry, I would be repeat it on US currency no problem, however not mine, I have no problem chopping up play money but the real thing is a different matter.
Steve :
I don't think you can make as durable or efficient a blade out of it for extreme use, or even moderate hard use, as you can out of steel.
I would change that just slightly to be :
I don't think you can make as efficient a blade out of it as you can out of steel.
Even if you just want light use, just go thinner with the steel and it will out cut the Talonite blade. The only exception to this is if there are people using Talonite blades with grinds like Ed Shott and R. J. Martin uses as that is about as optimal as you can get.
David Boye grinds some thin blades in cast Cobalt, probably the most optimal cutting blades in a Cobalt alloy being made (.01" behind the edge). Far more acute than what I have seen posted for Talonite (.02"+ behind the edge), still not as acute as Schott and Martin (few are), but as acute as Phil Wilson and definately in the high performance class.
Problem is though is that they are very weak compared to the same ones in his cast steel. Thanks to Will York I have a loan of two identical hunters in both materials and the Cobalt will take edge damage far easier than the steel one, even simply cutting cardboard. It rolls quickly and then with continued cutting breaks apart. To be specific, after cutting 3000 cm of cardboard with both :
"[Dendritic Cobalt] There were two areas about 2mm long that were missing pieces about .2 mm deep and a couple of smaller sections were broke away leaving gaps about 1mm long and .1 mm deep. The Dendritic steel blade did not fracture and was only slightly reflecting light in a few places. [/quote]
I have seen similar with many other types of uses including simply using both in the kitchen and observing the resulting damage, to be specific, after one such week :
"Under 10X the Cobalt blade has one large dent about .2mm deep and 2mm long. It also has a couple of small ones about .1 mm deep and 1mm long. The Steel blade has no damage visible at that level."
The .2mm deep dent can be seen easily by eye.
Same behavior can be seen in any type of cutting, for example I did some chopping with a forged 6BH blade and the edge rolled almost immediately (150 chops) on some very seasoned (10+ years) Pine (light chops, elbow only). The same stress did not significantly effect the Strider WB, Project I, or Busse Battle Mistress.
-Cliff
