Cougar, if you look at the tests you will find a strong reluctance to compare the same results to the better steels. They are presenting by themselves often using something that any blades can do as an example of high performance which is one of the most common ways to hype a material as you can be very misleading but you are not exactly lying.
For example, as for the animal tests, I have relatives who do a lot of hunting. They can all dress on average 1-2 moose for example without sharpening and they use what would be described here as very low end steels. Medium carbon content, no alloys, very soft. I have watched my grandfather butcher lots of animals including pigs without resharpening and he used whatever knife was given to him (he did it for other people).
The other sign of Talonite hype is the constant contradiction in description by those that are representing it as a good blade material. For example, when Simonich first noted that it did not cut rope well, I commented that if it has low bite when polished just leave the finish coarse. He replied saying that the coarse edge degrades almost immediately. However when I mentioned the same thing to Ron Hood he said that the micro-serrations do not break off and the edge will maintain an aggressive finish.
Or for example, Hood posted an extensive comparision between a Talonite blade and a Busse Combat one in which the blades were used on very harsh materials and the Talonite one was much more durable. However now it is being described as "well not the best thing for big blades". Yet it handles heavy edge stress better than a Busse Combat and doesn't chip or dent? If that doesn't set a functional standard I don't know what does.
Right above Bob commented that the edge does not roll given the right geometry. Which is simply false. No matter what geometry you use, even thick fully convex highly polished, the very edge is still extremely thin and will roll on even the best of steels (strongest) much sooner than you will see blunting due to wear. Because Talonite is much weaker it does this quicker than the high end steels. As Tom Mayo commented awhile ago when he noted that when most users say the knife has blunted they are just seeing edge roll.
These are just a few of the contradictions, there are lots more. Just search old posts.
There is also lots of information on Talonite from makers who do not feel that it makes as good a blade material as the high end steels. You don't see much of such discussion here for exactly the type of posts that appear in this thread. They don't want to put off possible customers or other makers. However at times such makers have make a comment here or there. If you search old threads you will find out who to drop an email to.
Blues :
Pretty impressive in my eyes.
A $10 factory ontario machete will do that. That is the standard you are setting Talonite to.
Tom :
Ok..a penny is soft and weak...so is talonite, so it follows that one will not cut the other....
Tom these are relative terms. Talonite is soft and weak compared to high end blade steels, it is strong and hard compared to copper - as are even the low quality cutlery steels like 420-J2.
from what is inferred the stuff is soft and weak and not worth making a knife out of.
I never said that. However I do believe there are far better materials unless you want the extreme corrosion resistance of Talonite. Interesting enough, what you describe was pretty much exactly the attitude you had about Stellite 6K a couple of years ago before Talonite became a very hot blade material. Back then you were strongly pushing the CPM stailness steels including over Stellite 6k.
As for people have an agenda because they are not being positive and are always putting it down in threads. I stayed out of this thread until some very misleading remarks started being made. And as for adgendas, some of strongest promotion is coming from the makers that are selling Talonite blades. If someone found out that a maker was giving me $50 for ever positive comment that I made about his knives people would very rightly ignore anything I said about their knives. Well the makers are getting exactly this from every positive claim being made.
It boggles me that anyone would take a makers description of something he is selling as being unbiased. Is this the way you shop for products in general or is it just knife specific?
-Cliff
[This message has been edited by Cliff Stamp (edited 07-09-2000).]
