Tank Buster Specs & Options. . . . YOWZA!!!
I still don't see myself ponying up the money for a DC or satin - coated is fine for me, and if I knock most of the coating off, then it just gives the knife character :thumbup:
I will be getting one LE & one DC. Anything else I can afford will be coated.
Specifications:
Blade Length: 6"
Overall Length: 11.5"
Cutting Edge Length:
With Choil: 5 7/8"
Without Choil: 6 3/8"
How is the cutting edge longer than the blade length ? Is the blade length measured to the top of the handle and the choil-less edge meaured to the bottom of the handle ?
EDIT: I don't know, doesn't look like that all works either.
Specifications:
Blade Length: 6"
With Choil: 5 7/8"
In order to measure the cutting edge, we place the blade's edge on a piece of paper and roll it forward towards the tip. That way we get an accurate measure of the edge as it sweeps towards the tip. In other words, the extra length that you're seeing is from the curve in the cutting edge. :thumbup:
Make sense?
Jerry :D
Make sense?
Jerry :D
Learn somethin' new every day on the forums! Makes sense!:thumbup:
My "makes sense" window is somewhere in-between 5 and 6 drinks along with my pool playing skills! Whereas my INFI purchasing window is between 1 and pass-out # of drinks and then I may not learn of the purchase til the next day!:eek::D:D
Ya would-uv had me with the Tank Buster tonight Jerry!:D:D:D
I've got a strong feeling that you're a repeat offender. . . . I'm thinkin' that you'll be primed up again by the weekend!!!. . . If not. . . No worries!. . . Because I will be!!!! :D
Jerry :thumbup:
(sigh) i just can't think anymore about all these options..... either i drank too much, or not enough. maybe i just work too much...
I'm getting ready to leave the shop now. Within the hour I will be racked and having nightmares about the tsunami of Tank Buster options that are about to hit the production floor!!! :eek:. . . . Just one more reason that I'm glad not to be Garth!!!! :eek: :D
Night all. . . .
Jerry :D
i hate it when that happens. i thought i had a problem, glad this is common.
BTW Bossman, is the new tequilla sunrise g-10 NOT going to be a option on this one???
So how does this knife compare, sizewise, with the JackHammer? About the same, no?
I wonder if any of the wizards here could Chop up a comparison?
Whoaa...so many options !
Boss Hog, with all the combos available for combat grade, then I can get all the features of an LE in a CG except for the tigerhide micarta?
Am I getting it correct?
