- Aug 7, 2007
Doesn't matter, AUS8A is steel you get when better steels aren't available. It's ok... but not goo enough. And I do not think that the relief cut in titanium is too terribly week... we're basically talking about having to tear a 1/16th of titanium. Impossible? No... EXTREMELY unlikely yes. And I have to imagine it would take a lot more than 400 lbs at the lock to create enough force to shear that portion of the locking bar.
Good to see you don't have a prejudice to Aus 8a, I am pretty satisfied with it until now
Well, not to nit pick or anything but the mode of failure for the relief cut when the opened knife is subjected to closing (or some say negative forces) forces is by buckling and not shearing. Shearing 1/16th or Titanium is not easy but buckling it is significantly not too difficult don'cha know
Buckling of the relief is actually very good outcome instead considering a frame/liner lock may also fail due to the lockbar sliding off the angled blade cutoff. It happened to my ZT0200 and a Custom and with some diamond file (rounded in x-section shape) sorted that easy and with no bladeplay. This actually is rather uncommon.
Stop pin size is only a small amount of openign/cutting strength. Position has a great deal to do with it. The way in which is engages the blade is VERY important. And the materials of the pin itself and the materials of the blade matter a great deal also. You take a large stop pin made of cheap steel, positioned poorly, stopping a blade of realatively average steel.... and you're not promised a stronger stop than a knife that may have a perfectly positioned pin, made of better materials, stopping a more robust blade, with more intense engagement. Not saying either the Strider or Crusader pull this off... but I would take semi-production to custom's attention to detail over the mass produced assembly line junk that Cold Steel throws out.
In terms of position it is relative to the pivot of the blade. The distance of the stop pin (from the pivot) is not too different from most folders. However the actual distance i'm referring to is the vector component. Most folders are around (plus minus) and inch or so.
I am a patent holder for mechanical joint in Malaysia (for RC square piles joints) and the critical component is the steel pin which holds everything together by shear. I tested different materials for the pins from stainless cheapie steel (hey, I gotta save money you know
Sorry for giving a mass produced assembly lined junk (in my opinion it is everything you say but not junk, at least not ALL of their products) instead of something of higher class but I assume you wanted a mega strong folder with strength as priority.
Good luck in your searches. It'll be interesting to see how this pans out as I too am always looking for a strong (stronger) folder/blade.
