DrMegabyte
Basic Member
- May 29, 2017
a build out? Is that like the custom shop? I like the look of the suretouch handle. Is it more tacky for better grip?This 2024 116 I picked up is a "Build Out" model, 0116BO4-B, with a SureTouch™ handle and 420HC blade:
Thanks.A "Build Out" model is a model not found in the catalog, but built by the normal production process, not the Custom Knife Shop. As best I know there are two types of build outs:
1. A Dealer Special Order: A dealer asks for a special run and Buck builds it "to spec." The recent 192 Vanguard with Micarta Handles for Smokey Mountain Knife Works is an example of this type of "Build Out."
2. A Factory Build Out: Buck takes left over parts from other projects or from discontinued items and combines them to "use up" the spare parts. The Blue, 110 Slim with an S30V blade, currently available as "Web Special" is an example of this type. It uses the now discontinued 110 Blue Slim Select Frame and combines it with blades from the now discontinued 110 Slim Pro TRX.
Build outs always have the letters "BO" as part of their full model number.
Has not been updated in a while, but this post provides a list of older Build Out Models: https://www.bladeforums.com/threads/build-out-list.1678727/
My 116 is an example of a "Factory Build Out" using left over 116 blades from an earlier project and left over SureTouch handles from some tests Buck did with that material. SoureTouch is very "grippy" as a material as it combines G10 with Rubber. The currently available Stealth Run #11, the 119, uses it. Here is the manufacturer's page on SureTouch: https://www.ultrexcomposites.com/suretouch/
Thanks, that is helpful as it gives me the size of the 501 compared to the 55 I have. It says the 55 blade is 2.3 and the 501 2.5, so a little longer and the overall size of the 501 is a little bigger….. and a drop point of course. Thanks for the pics, now maybe I should get the 501 in magnacut or a higher end steel. 420hc is still good too, but just try a little more variety.I don't have a 503, but here's a 55 with a 501 if that helps.
View attachment 3059659View attachment 3059661
For the most part, I'm a light user these days so 420HC is fine. That said, the one in the pic is S35vnThanks, that is helpful as it gives me the size of the 501 compared to the 55 I have. It says the 55 blade is 2.3 and the 501 2.5, so a little longer and the overall size of the 501 is a little bigger….. and a drop point of course. Thanks for the pics, now maybe I should get the 501 in magnacut or a higher end steel. 420hc is still good too, but just try a little more variety.
If you are a BCCI member the annual club knife is a 501. Burgundy micarta, brass, and s30v.Thanks, that is helpful as it gives me the size of the 501 compared to the 55 I have. It says the 55 blade is 2.3 and the 501 2.5, so a little longer and the overall size of the 501 is a little bigger….. and a drop point of course. Thanks for the pics, now maybe I should get the 501 in magnacut or a higher end steel. 420hc is still good too, but just try a little more variety.
Yes. There is a guy or two on here who have modified stock knives like you described, and done a fantastic job. I don’t remember who off the top of my head, or I would point you to them. Buck also released a 110 in that configuration this past year. I think it was a Stealth Run. Everyone is expecting a matching 112 any time now. My hope is that the pocket clip is reversible for lefties, but the 110 was not. Time will tell!Anyone seen a traditional 110 or 112 with brass bolsters and wood handles but slimmer and with a clip? Like a traditional 110 but Slim dimensions, a thinner profile.
Didn't the stealth run have nickel silver bolsters?Buck also released a 110 in that configuration this past year. I think it was a Stealth Run.
