Good morning Nathan. I have a question on the Delta 3V that I thought I'd ask here. I'm still trying to get my mind wrapped around the results I'm seeing, and would like to make sure I'm describing it in proper terminology.
So going from the bolded in this quote:
When I used the D3V field knife on a couple of bucks back-to-back, gutting, skinning, and breaking through the joints with a lot of bone contact, this current version of the field knife held up/performed better/finished sharper than anything else I've used up to this point. Is this then what you've described in the bolded text as 'edge stability?' I've thought of this as wear resistance in the past, but am now wondering if I should really be using the term edge stability rather than wear resistance, what with the rough use I give it against bone. And maybe I'm just splitting hairs here, but do want to properly label said hairs if so.
So, for the use I'm describing and the results I'm seeing, is the terminology correct if I say that I am seeing an increase in edge retention due to the gain in edge stability from last revision 3V to Delta 3V?
Thanks in advance...
Dave
