- Sep 24, 2014
^^^ This!![]()
I think Jo has her own category... terror/pound. Wolverines and Honey Badgers fear Jo. And of course, Nathan does too, because he’s smart.
^^^ This!![]()
I'm dancing around my question I think. With the D3V configuration could you not turn out a 15 DPE razor which wouldn't deform or damage easily? To be fair, I'm only asking because of my recent goose hunting forays. I avoided boning the goose (shut up Casino!) to breast it out.edge stability doesn't really have anything to do with the thickness of the stock used. The primary grind might have a little influence on overall cutting ability, but not the stability of the edge itself per se.
the bottom end for edge stability for Delta 3V is around 13 degrees per side. There is too much carbide and chromium in it to go narrower than that. Below that you need a simple steel like W2 which can go down to perhaps 10? This is much narrower than most knives. Delta 3V shines at 15 to 20 which is on the narrow side of most users.
Because we have high strength and high hardness we can go thinner BTE than most steels, this is largely a function of yield strength which is around 320 KPSI on steel of this hardness, this is a higher strength-to-weight ratio than titanium, and 3V can achieve this level of hardness with good working toughness. So you can go pretty thin behind the edge. That said, the stiffness is a function of the geometry not the heat treat.
We had a dead goose decide he was alive, I stuck an EDC in it's head to change its mind. I'm very new to hunting models.
I was going to add some detail to the encyclopedia - which scales are interchangeable?
Utility Fighter & Double Edge Fighter - do they match the Shiv as well?
EDC, EDC2, and EDC3 all interchange, but the scales on the EDC2 & EDC3 are slightly thicker?
Choppers - do the RLC, LC, MC, HC, and BC all share the same scales? The Behemother? The HDFK?
Anything else?
Edit- found my answer! I need a second job...We are producing them right now. I'll have a batch ready for heat treat in about a week. We will have FK2 ready for sale in November.
Do you know how many will be offered for this November sale? As in will I need to work on my clicking over the next month.
Anything else?
Same thing with the light/prototype BC choppers vs. the production choppersCool. I know the UF answer is no. The bolt pattern matches the Shiv, but the profile is slightly different.
Same thing with the light/prototype BC choppers vs. the production choppers![]()
Nathan, would the scales from a medium chopper or hdmc fit a light chopper?
I'm sorry no
Nathan will handle scales from a Light Chopper fit on the prototype Heavy Chopper? I hold the blades that you make in the highest regard, thank you in advance for time.
Yes I think so. the shapes are different but the bolt holes line up and I think the profile is pretty close.
This has probably been covered but I can't seem to find it..
Is there a post or page showcasing all available scale materials/colors? Hoping to get in on the ufk sale next week and need help with scale choice.
Yes, same scalesI know most if not all of the choppers use the same handle scales ... but I am just wondering if the Behemother currently open for order uses the same handle scales as the MC/HDMC ?
If it does that would change my order if I jump in for one.
Thanks - JJ
How do I choose!!!I don't know what will be available but this might help see what's what
