the original FK is retired
Sad to hear but understood
So will there ever be a fk size knife , designed like the UF ?
Still hoping for the opposite of the BAD idea version
Thank you
Huh? I are confuse
The FK2 is about the same size as the OGFK
I might be misunderstanding you, but UF = Utility Fighter. FK2 = Field Knife 2.0My bad there ^
So I guess I’m trying ask. Will there be a knife fk size but robust like the UF. The UF has certain design qualities making it pretty unbreakable. Not looking to drive the knife tip through 1” steel. Not asking or looking for that at all.
I think I broke my brain yesterday lol. Having hardtime getting my words right today lol![]()
I thought it was the Shiv that was built to be able to hammer a loophole in a wall if necessary?You are pretty close
But I don’t believe the FK2 / UFK has a reinforced tip. I think I’ve asked Nathan this before. The UF in standard form comes with Nathan’s full warranty. The UF has reinforced tip with more meat behind the edge. I think it was for that rare situation you need to poke a hole in cinderblockThe UF if I recall, May be light weight but hits wayyyy above its weight class
But hey I could be wrong
I’m sure Nathan will chime in![]()
That will work tooI thought it was the Shiv that was built to be able to hammer a loophole in a wall if necessary?
I've got an FK2 and both the UF and DEF.I know about the shiv, but I am thinking of the UF ^^^
No. I’m sure Jo will get you taken care of.If you are told to email jo about finalizing the purchase but don’t hear back does that mean I was too slow? Is the email process first come first serve as well? New to forum and was a little confused overall I guess.
The FK2 has a noticeably more robust tip geometry.
I don't have a Shiv, but IIRC from posted photos, it's also got a very robust looking tip. The DEF has a nicely tapered, stabby tip, next comes the UF, then the FK2 in order of increasing thickness behind the tip.
Maybe if someone has a Shiv, FK2 and UF, they can post a pic with all 3 tip thicknesses to compare.
