I know this is an “Ask Nathan” thread, but a question for you is the Sprngfield worth getting the kinks worked out or should I just spend a little more and not have to worry about it?
Depends... a lot of them seem to have had function issues, but most of the function issues seem to be related to SA running the recoil spring weight as light as humanly possible combined with some roughness on the disconnector. Other known issues are poor extractor 'tuning,' and the chambers being incorrect dimensions.
So it depends. If you get one that works, then you have a very comfortable, soft-shooting 2011 for $1,500. If yours
doesn't work, then the odds are a $15 spring kit from Wolff will fix it. But if
that doesn't work, then you'll have to send it back to SA, and frankly my experience with that was that they didn't listen to a word of the two-page letter I sent them outlining things I thought were causing the malfunctions, they just tore it apart, measured everything, and corrected everything that was out of spec, which apparently in my case was just the chamber dimensions. So they reamed and polished the chamber. My local smith buffed the feed ramp and the disconnector. None of those things fixed it, but dropping in a 14-lb Wolff recoil spring did. I had told SA that I thought lightening the mainspring and using a slightly heavier recoil spring would probably fix it, because I was having a 10% failure to feed issue where the bullets nosedived into the ramp without ever getting into the chamber in the first place, so it seemed unlikely that was related to the
chamber dimensions...
The 5" model has a 9-lb recoil spring, and the 4.25" has a 12-lb recoil spring. If yours feels sluggish returning to battery and you have failure to feed issues, increasing that to 11- and 14-lb springs seems to help in many cases.
The obvious question is "Are the tradeoffs worth the savings over a Staccato P or C2?
My best answer is... it depends on whether the difference is a
little bit of money to you or a
lot of bit of money. It's not a small amount of money to me, I mean, you could get a SA 1911DS Prodigy
and a Shadow Systems MR920 Elite for the same price as a Staccato P or C2 built to match the Prodigy features.
Comparing it against the P, which is closer in size, the base-model P is $600 more expensive than a 4.25" Prodigy, and if you add the optic cut, it's another $300 more expensive. Plus the Prodigy grip module is just flat better than the Staccato Gen 2 texture with the star logo texturing, so if you want the Staccato Tac grip module, which is as good as the Prodigy one, that's another $100 on top, so now you're at $1,000 more than a Prodigy. The Prodigy also comes stock with the Agency optic mounting system, which is a really nice system, although the plates are sold separately.
Against the C2, the base-model C2 is $500 more expensive, add the optic cut for $300, and you can't get the Tac grip module for the C2, so send it to Elusive Arms for a retexture, and that's another $200 or so including shipping, aaaaand it's $1,000 more than a Prodigy.
That being said, the Prodigy is full of MIM parts, SA didn't even bother trying to tune the extractor, and you'll probably need to buy a spring kit. The spring kit is cheap, so no big deal, but if you're anal about MIM parts, replacing them with EGW or Wilson or Ed Brown parts or something and paying a smith to fit them if you can't do it yourself will make up most of that $1,000 difference between SA and Staccato. Alternatively, you can ship it back and forth to SA until they fix it to your satisfaction. So what I'm saying there is you can't make a Staccato for $1,000 less than Staccato charges, and making a Prodigy into a Staccato equivalent will eat up all the cost savings you saved on the base gun.
You can also, I think, get the best bang for your buck by keeping most of the stock parts in a Prodigy and just having a decent smith fit and tune a pair of new Wilson Combat Bulletproof extractors and doing the spring weight change. The rest of the parts are MIM, but they're OK, and you probably won't notice the difference in shooting it. You can always change the rest of the ignition parts and the slide stop, grip safety, and trigger out later.
EDIT: Actually, in addition to the extractor, there is one other thing - the guide rod is a screw-in two-piece, which is just a terrible idea on SA's part. The 1990s called, and they want their guide rod back. This doesn't impair
function, but you will need to torque that down hard and regularly tighten it until you eventually get annoyed enough to replace it with a Dawson Precision guide rod.
So the answer for the end user is - are you satisfied with the risks of doing some tinkering on a Prodigy to get a functioning 2011? Right now, I have a functioning 2011, but I had to ship it back to SA once, buy several different-weight spring kits on my own dime (wasn't sure which weight would be best, so got several), buy two Staccato mags (hedging against the possibility that it was the SA OEM mags that were the issue) and have my smith polish the feed ramp and disconnector. But my gun works, and I was out about a month, 700 rounds of troubleshooting ammunition, $45 in parts, $120 in extra magazines, and a fair amount of hassle to get it that way, and to be honest, the extractor should be replaced and tuned, because right now it flings brass right over your right shoulder, and sometimes you get brass to face. But it works.
The plus is... it is a real comfortable, soft shooter. It's stupid accurate. Once it works, it's a real fun gun.
Idunno, it just depends on what I happen to have at the moment? SSSDFK, DEF and?
Well, I do have a DEF from the preorder and a SS SDFK, but if you're interested in a trade, boss, I'd be all ears, especially if one of those hideous clip point bowie SS SDFKs was part of it and/or you could muscle Mark into a CR35. Please see above for my full disclosure about the gun's history, though. The gun was $1,500, so that'd be what I'd estimate trade value at, and I'd throw in a 17- and 20-round Staccato mag as well on top, which are $60 each usually.
