We're not generally driven by aesthetic considerations.
People sometimes think about these things from the wrong direction. There are two basic considerations about the primary grind geometry, everything else is driven by that. There is the primary grind angle and there is the thickness behind the edge (BTE).
Without going into specifics about geometry, lets say a particular knife needs a primary grind angle of a certain amount for particular cutting characteristics and durability. And the same concerns drive the BTE thickness. You end up with a certain geometry that starts behind the edge and extrapolates out from there. Where it intersects your flats is driven by your stock thickness. Sometimes it's high, like on a kitchen knife where bevel durability is unimportant compared to slicing ability, sometimes it's low like a machete where the stock is thin and the bevels are thick (obtuse).
Your stock thickness is driven by gross blade durability considerations and weight. Most knives are better light (and thin stock leads to saber grinds, at a given bevel angle), but choppers need weight in particular places to work well.
Things you can do to increase the strength of a knife are increase the stock thickness (all else being equal, this raises the grind) and increase the primary grind angles (lowers the grind) and increase the BTE thickness (lowers the grind).
When we think of thickness, we're actually thinking of both the BTE and the primary grind angle, and sometimes they can be somewhat interchangeable because both effect the meat behind the edge and up in the blade that resist deformation and damage from rough use and chopping. I tend to go for moderate bevel grind angles and thinner BTE because it's durable and cuts well. A similar level of durability can be had with a full flat grind, but it would require a thicker BTE to achieve the same bevel stability. The durability in chopping might be the same, but the thinner BTE knife will generally make smaller cuts better, all else being equal. And there is a sweet spot for chopping wood, not just for durability but for penetration and resistance to sticking, and it is not super acute. <--- which in moderate thickness leads to a saber grind.
Also, all else being equal, the sharp corners behind the FFG will tend to stick in wood if buried. If one does a FFG that's used for chopping it helps to have some relief behind the bevels at the spine to reduce this. <--- which gets you back to being a saber grind...
There are arguments for all grind types (including compound grinds, convex grinds and S grinds) but I have gravitated towards saber grinds. The thing to remember is, your angles and thickness are what's important, they're just difficult to see. The resulting intersection lines are as much a function of stock thickness as angles. Letting these arbitrary lines drive a design without consideration of the underlining geometry is letting the tail wag the dog.
