Jack Lewis
Basic Member
- Nov 24, 2007
Ah, man. I’m going to need to buy whatever the forthcoming four-inch variety is. I feel like that size is the sweet spot, for me.
Something something penis joke something something.Ah, man. I’m going to need to buy whatever the forthcoming four-inch variety is. I feel like that size is the sweet spot, for me.
Hi Nate, are you gonna do a pre-order for the upcoming 4inch slicer ?
ProbablyHi Nate, are you gonna do a pre-order for the upcoming 4inch slicer ?
Nathan the Machinist should we expect another one of your sneaky Friday one-offs this week? I’d like to help someone out with a proxy but I’m hesitant in case you drop in something unexpected. I’m jonesing for a SC
There will definitely be a few extra K20Hi Nathan, do you think there will be any extra K20s? And/or a dagger preorder? Thank you.
Nathan the Machinist Now that choppers are being produced, are you still planning the limited Behemother chopper run you previously slated for 2026?
I haven't found the answer to this anywhere, so here goes.
Nathan the Machinist is the "hard and thin" D3V in the #BAD IDEA FK2 the same as the tweaked version of D3V in the FK3? If different, what's the difference? TIA!
Awesome, thank you for the answer! I knew you'd said you had input to the melts more recently, so I wondered if this new tweaked version differed from the OG hard and thin. Thanks!No, this is more evolved. We have, obviously, been tweaking heat treats for a while. As we've gotten larger, we have been able to tweak the steel production process as well. The tweaks to this steel go all the way to the very beginning of the steel production process, allowing smaller finer carbides which play better at higher hardness. We buy a lot of 3V now and are able to massage it a little bit here and there for different applications.
Where would you be able to score one of those extra k20s?There will definitely be a few extra K20
Dagger pre-order seems unlikely
Thanks
Weren’t the Daggers a byproduct of the K18Friday sales
The Atlanta blade show
The October Outlaw cut here at the compound
Going to try to have some daggers here in October. Although I guess we'll see how that pans out
The taper then flare into the pommel is something elseDaggers are pretty
Well you say "the" daggers, but surely you're aware those aren't the only daggers?
View attachment 3106056View attachment 3106057
I like daggers
Daggers are pretty
