- Mar 11, 2011
Thanks man, appreciate it. Like I said though, I completely copied the idea from someone else.Dubz, that thing is INCREDIBLE! Brilliant work.
Dubz, I'm still contemplating legs, but I am totally going to steal that computer fan cover idea for sure.
I looked around on the 'bay and saw some thinner stock stuff and one thicker one like you have. Going to look locally first though.
Emberlit's are freakin' great man. Doesn't the heat take the paint off the table?
It didnt yet![]()
Must be some good paint. Either that, or the Emberlit doesn't get as hot on the bottom as I thought.
I like that DIY stove, Dubz! Have you tested the PC fan guard with heat? I'm wondering if the metal holds up to it or not.
Here's the only fail in the kit. You would think they'd have designed the handles so that you could combine the two shorter ones into one long handle. Not so.
The tabs don't quite catch. Well, one catches, but the other side does not. Would probably still work, but it's not as trustworthy as it might be.
So after I bought the Rothco lids and I couldnt even come close to getting them to fit a GI cup I got a stainless Rothco cup and the little stove that is supposed to nest over the cup. Well it dosnt. I guess thats what you get for $5.![]()
I was looking into buying the Rothco lids and found out that they only fit the Rothco cups. I also read that the Rothco canteen goes into the stove and then both should fit into the cup. Does that work?
