The breaking of a new Schrade.
He didn't say that. Making stuff up never helps an argument.
Well then. I feel sorry for you. He did say "no, you couldn't".
Until you can add constructive posts I will just ignore your poor attempts to bring others to your level. I've known people like you. Worked with plenty. The moment you treat them like the way they treat you they head off to the boss and tattle and complain until the boss explains to you their "situation".
If use google and watch YouTube is the best you have then you don't have much for me.
Bye, have fun with your agenda. I look forward to discussing knife topics with the other members.
This is exactly what I said. I put the part of my post you seem to have skipped in bold:
No, you couldn't. Not in the way he breaks them. ANYBODY can stick a knife in a vise, slip a pipe on it and bust it.
The point was that the knife in the video failed MUCH earlier than others.
That means what I'm saying is that you could not bust a knife in under a minute the way Noss does.
Yes, you can clamp a knife in a vise, put a long length of pipe over the handle and pull until it breaks. Anybody can.
The point was that the knife in the video failed much earlier than others.
Okay Duane, okay :rolleyes:
You won't find many people here who agree with your argument. You have hitched you cart to another person who consistently makes poor arguments that are easily disproven, so you are in good company. Why are you here arguing with us again if we are all wrong?
You know, when someone says something like this it completely discredits every thing they have said in the past and will say in the future. It takes about 5 seconds to of googling to prove you wrong. Even your buddy Sam says hollow handle knives have failed. He as pictures too!
Then if it takes 5 seconds, why has nobody come up with any photos of any examples by now? It's been like several weeks... I'll try to help you on that later, as you badly need it...
I pointed out the JK1 that Sam Wilson has found, and that was the only one: Not that great a representative example anyway, both on the design and quality...
It was posted by someone else on bladesforums, and remains the one genuine broken hollow handle tang (besides the Bill Bagwell Buckmaster article):
People come up with the dumb example of the Chris Reeves Project being hit with metal (Cliff Stamp also broke his), which is blade breakage. I never even mentionned blade breakage: What the heck does blade breakage have to do with hollow handles? Obviously I am dealing here with technical sophistication of a high order...
I talked about tang breakage: Besides the JK1 above, I have never seen a seriously made Hollow Handle fail at the tang, and for obvious reasons: A smaller tang of the same stock will always be much harder to break than a bigger tang of the same stock, just like a smaller blade of the same stock is harder to break than a bigger blade of the same stock, all else being equal...
To argue that small tangs are easier to break than long tangs is just as stupid as argueing that long blades are stronger than small blades. In fact, to argue that any smaller object is more susceptible to breakage than a larger object, based on size alone, is about as close to terminal stupidity as one can get...
Unfortunately for the naysayers, there isn't much about a machined steel tube handle that is susceptible to breakage either, so all that's left is the attachement method, of which there can be a wide variety in quality and design... Again, unfortunately for the naysayers, there are many easy ways to make the attachment method quite inaccessible to leverage, and separate parts are definitely less susceptible to vibration-induced breakage as well, though certainly not immune, depending on design.
I'll try to help you guys, since your case is so obviously dire:
So show me a picture of a broken tang on anyone of those: Buck Buckmaster; Lile First Blood, Mission or Sly II; Timberline/Neeley SA; Parrish Survivor; RJ Martin Blackbird; Randall Model 18; Wall First Blood or Model 18 style; Andrew Clifford Sly II; Steve Vorhees Rambo style, and you will get, free of any charge, drum roll please:
A mint condition Pre-Dot Lile Sly II, Cerakoated not original finish (since the original sandblasted finish was really crap): It is being refurbished and Cerakoated now, so if you are quick enough you may get to choose the Cerakoat colour... Sheath will be an original Lile Sly II sheath, brown and no hone, dead mint but with a nice waterproof matte coat. This is originally designed to be a cordless handle Sly II, so a straight smooth tube handle, and no compass in the buttcap, but otherwise mint-looking, and the edge will a professionally done 30 degree inclusive edge, much sharper than the pathetic original 80 degree edge...
These are the only conditions I put on the photo: You must be able to source it as older than this challenge, otherwise you don't just get a Lile by taking a sledgehammer to you Buckmaster...
Obviously the Buckmaster is the one that will do me in, since there was over 110 000 made... With this in mind, the other limitation I put in is that the Buckmaster in the photo must have at least the Patent pending or later marking on the same side as "Buck 184", as earlier ones could have had the tang not annealed, and so don't count... That just eliminates about 13 000 out of 110 000... And I will also exclude the one Bill Bagwell broke on an anvil in the "Big blade bust" SOF article, regardless of what its markings were: Too easy...
I will likely lose this challenge, especially with the Buckmaster in it, but then again who know? It is clear and simple enough: You say Hollow handle short tangs break? Then put up and provide a picture out of the large selection above, and you get a mint-looking 2K Lile knife in much better shape than when it left the shop...
This is what you'll get, a bit bland but...:
So let's see where are all those broken tangs: Can't wait to see them...: First one to post a dated pic wins. If nothing comes up, then we'll really know who knows what they are talking about...
Gaston
P.S. In case you are wondering if I'll really come through, note that I don't like the knife and rarely if ever sell my knives, so make of this what you will, but please don't pretend it's because you think I won't send you a free Lile, and pay postage to boot...
Since the buyout, I've been avoiding Taylor Schrades as an option because I was not convinced of any sort of quality, or care by the company. This has proven otherwise. I agree that its an obvious defect from manufacturer, and one that could have happened to any knife. Heck, even the legendary BK2s get busted from time to time, turns out making a knife is not that easy. There are lots of reasons a crack could form there, and several factors could have come into play there.
However the response you've gotten from them proves that maybe they are worth looking at in future. Hopefully they are working to maintain the legacy of the company, and I will be looking to them in future for gifts and the like. I hope that good customer service is also a mark of them refining their production in general and bringing things back to the old standards.
Guys I'm not sure why you're so hung up on "full tang" and "hollow handles" knives. I think we all can agree that the highest degree of security and indestructible strength comes from slip joints. I've never seen one fail so they must never fail. And that's science.
But seriously good on Schrade.
Oh man... Let me catch my breath.
Thanks for the laugh. Science!
Now available on Amazon...
So, where are all those ubiquitous broken tangs hiding? Did I not hear it was a 5 seconds search?
Not even the promise of a $2000 knife can bring them out?
Could that be the sound hot air makes?
Gaston
