- Feb 25, 2012
I've been thinking about the proposed scenario. Couple of problems. If you have hypothermia you would probably die before your "fire" would warm you. You would be better off with a dry rescue blanket.
The reason is that if everything is wet you would need to process a great deal of wood to be able to start and maintain a fire that would be capable of increasing your core temp. If you aren't we'll enough to process the wood you probably won't make it. The fire you would be able to start with the matches might last you a minute, but certainly will not help your survival situation.
A better option would be a supply of dry tinder which would give you a better chance to dry out some of the larger wet wood, but again you would still need to process wood to keep the fire going for a meaningful amount of time. Look at some of the other posts where people have tries to start fires in the winter and struggled even with optimal tools.
If you have the energy to process wood it makes the advantage between the two options less clear. Matches are easier, but you get less chances. If you have firesteel and tinder it reduces the need to make a perfect nest and an even more enticing option.
