- Jul 11, 2009
don't forget that the RAT DPx H•E•S•T was designed to used for traps, improvised spears, weapons and with a little Newtonian physics and even double mounting for many other uses. For example the "holes" in the knife allow you to attach the H•E•S•T to more H•E•S•Ts, work benches, long handles. They can be used as lashing points along with the mirrored choil/wire breaker and "bottle opener". The bottle opener and pry bar were also designed for dynamic release points in traps and booby traps. The large open handle allows a vertical handle (much like an axe) and can be doubled up with another H•E•S•T as workable hoe, axe or splitting device.
You can hammer the pommel with a rock to make a splitter, sharpen the pry bar to make a kindling stripper and space two H•E•S•T's with bolts and washers to make your own handle to cut skin into laces.
The range of applications in a austere environment are impressive. It just takes imagination and a few basic nuts, bolts and wires. All which can be carried in the handle of course
