Same year ago I had the opportunity to hold that knife in my hand in store in Wien. With 7 mm. spine it look like you can stuck that blade between some rocks and use it as anchor to pull your Land cruiser from mud !
You don t make knife from 7mm steel usable for cutting sausage on a picnic ! That knife should have strong reliable tang .Wood on handle on ANY knife should be there just to make handle comfortable to hold .And even if wood crack or break that knife should still be usable in emergency situation! Any knife is enough good for ordinary task and to slice sausages for grilling , but when ***** hit the FAN I want that 600 $ knife to be capable to do little more then that ! I will survive if edge chip , roll on edge but without handle ??? They ask 600 $ for that knife and they weld nut on 2 inch long and thin tang ??? Do you hear Fallkniven ? Don t spare on steel !! WE pay that !!
I think i make one knife like what I want to have when **** hit the fan.This is 6mm thick blade on spine ,Yakut stile knife .This is tang and this is handle .If you intentionally want to destroy the handle it will require a lot of effort and time and again the knife will be usable.
First i mold carbon fiber on ricasso side ,look at that tang
Then i make wood handle from walnut/tight fit/ and finished end of handle with carbon fiber molded direct on tang at butt.Of curse there are notches on tang so carbon can hold strong...
