You know they make this stuff called glue? That break looks like it could be fitted back together well. Tape it tight while the glue dries. Sand off the excess and squeeze out, and the break should be pretty much invisible.First up was drilling the clip off the scales. The screws were in there good so I needed to extract the screws.
I thought I learned something the first time I did this.
Apparently not because as I was doing the countersinks...
I almost packed up and went home.
There went like 12 bucks worth of cocobolo!
Okay, take a deep breath!
yeah I looked at it and looked at it.You know they make this stuff called glue? That break looks like it could be fitted back together well. Tape it tight while the glue dries. Sand off the excess and squeeze out, and the break should be pretty much invisible.
O.B.
O Old Biker Sometimes gluing does work...but it’s rare that you cant see the crack. :/
Case in pointjideta ... I was fuming when I dropped and broke this scale in half while finishing up one of my “Thistles.” You can see the crack running through the front pin. It looks ok, but I wouldn’t send this out to a customer. Luckily, this was the one I was keeping. Haha.
What happened was I did a shitty job with the epoxy and the liner; I didn't bother to clamp so the scale came right off the G10. I actually cracked the other side first and had re-glued and clamped that while breaking the second side.
In the end I said f*ck it, I got another set, might as well do it the right way. I tossed the first set.
Instead of using a giant old regular bit, I busted out the Forstners for the second set and got a much nicer countersink (which I should have done the first time).
YEah I'll bust out the Titebond depending on how scarce the source material is and how far along in the project I am. I don't usually sell my wood stuff but yeah if I'm making it for someone it doesn't leave the shop. I'll usually just start over. The problem is no matter how good the repair job, other folks might not know, but YOU know.
I don't usually work wood this small and thin so I'm still learning.
And messing up!
I don't have one of the Lion Steel knives. They are way outside my budget. Those that have one and talk about them in the "Traditional" forum don't mention them having blade play. Trust me ... if they did, that would be a major issue/defect over there.I have wanted one of these knives for years. Do they have any blade play? I know most slippies have some.
Awesome Micarta scales on that Victorinox! Where did you get them?A few favorites:
Spikediesel makes them himself!Awesome Micarta scales on that Victorinox! Where did you get them?
Beautiful!!!I haven't seen any blade play on any of my slipjoints, only on lockback knives. I have a lot of very nice folders, some much more expensive than the Roundhead and Shuffler you were asking about but for my daily carry it's always my Roundhead slim (titanium handles) in my pocket.
Here's one I worked on a bit.
