MOD 4, in case anyone was wondering:
A lot of comments along the lines of "this guy's a snob" but no one has contradicted anything he's said except to say the 2 batons well. Does the 2 do anything of the things he's talking about better? Will it carve traps and hearth boards better? Will it out perform a knife and saw combo? If you're batonning a 2 inch stick like he says, does the 2 do THAT better? Everything he's said is spot on from my experience. It seems there's more bias here then in that article IMO.
read a little closer maybe? he's been contradicted on several points. accurately.
he drew conclusions on the history of the blade, without knowing it, even though much of that information is available with some googling. including apparently the designer name, KaBar's involvement, comparing it to a knife made decades later (for a similar purpose oddly enough to the BK8) - perhaps insulting a lot of designers in the process, BK2 STARTED the trend for a production sharpened prybar, based on the MOD knife (back to egress tools)...
apparently it's not widely known that if you can convex a BK2, it becomes a cutting machine. factory edges are ... suggestions.
Show me a single knife that outperforms a knife/saw combo....
Will it pry open a car door better? Yes
Will it baton through emergency safety glass better? Yes
Will it break rocks, nuts, or bark better? Yes
Will it cause more damage if you had to strike someone in the skull with it? Yes
See where I am going? There is bias in both directions on this. I can come up with many "tests" that would favor a BK2. As I said, the 2 isn't for everyone, but it certainly has its uses. I do agree with a lot of his philosophy though. Over the years my knives has gotten thinner and thinner...but I still keep the 2 around just in case.
So you are saying the only things the Becker does better is tasks where you shouldn't be using a knife anyways? Again I say I personally find the BK2 (unlike other models in the lineup which I think are great) to be useless.
Bias toward Beckers in the Becker subforum? Why that's just crazy talk.
I don't care what is said here: For vs Against, Viable blade or sharpened prybar, Camper or Utility tool, Opinionated Reasoning or Fandom Biased, It's all BS!!
Point blank: My 2 works for ME and what I need it for. It has done everything I have asked regardless of task and has never failed......And what I need it for has nothing AT ALL to do with You or what You need. If you don't like that I appreciate it and want it and can use it.......GFY!!
