Matthew Gregory
Chief Executive in charge of Entertainment
- Jan 12, 2005
There have been instances where I've been less than careful with a finished blade.
I know. Go figure.
Anyway, when you get a scratch or a scuff on a hand-finished blade, usually you sit on the shop floor and cry for a little while, then you have to figure out how the hell to hold the thing while you sand the scratch out. In order to do that, I made this:
A scrap piece of aluminum with several 1"x1/2"x.250" N52 high power neodymium magnets stuck to it with serious adhesive.
IMMEDIATELY cover the magnets with a couple layers of tape - if you don't, you'll forever be chasing stuff off the surface.
Throw it in the ol' vise when you need it:
Cover both the magnets AND the other side of the blade in a couple layers of FRESH tape before you use it. ALWAYS USE FRESH TAPE!!!!! The one time you don't and realize you just MF'd the other side of the blade because of a tiny bit of mill swarf you didn't see will likely be enough to reinforce the importance of a fresh layer of tape, but go ahead and don't listen to me. Learn it the hard way. See if I care.
You can now hit pretty much anywhere on the blade you need to, including the spine, without interference. The knife won't slip unless you're a total dumbass and are using enough force to move planets. I'm only like that after coffee, so just lay off the energy drinks for a bit and you should be good to go. You'll need to lever the knife off the magnets. They REALLY hold. Well in excess of fifty pounds of force, here.
I have a larger version of this for bigger blades, but you get the idea.
I buy my magnets from K&J Magnetics. Great people to work with and a HUGE selection.
Hope this helps.
I know. Go figure.
Hope this helps.
