Phillip Patton
- Jul 25, 2005
I originally got into forging for one reason: Damascus. I was quite happy grinding knives out of 1095 bar stock, but I saw some pictures of this strange material called pattern welded steel, and I wanted to make it myself.
Aside from damascus, the reason I forge is that some of the steels I use just aren't available in flat stock. W2 and L6, mainly.
I'm convinced what makes a good knife or bad knife is the heat treating, NOT whether it was forged or not. (Edge geometry makes a difference too.)
Someone in this thread wondered if stock removal is a short cut. I would say, it's not a shortcut, it's more efficient. People say forging is less wasteful, because less of the steel ends up as dust on the floor. (true, but even at that, some of the steel that would end up as dust under the grinder, instead ends up as scale next to the anvil)
You MIGHT be saving a little steel by forging, but let's look at the areas where you're spending more:
Propane or coal. If you're grinding, you don't need either one. (unless you want to use one for heat treating)
Fuel/electricity for thermal cycling and annealing. Precision ground stock is all ready to go, no thermal treatments needed besides hardening and tempering.
Time. Time to forge, time to thermal cycle, time to anneal.
And you still have to grind a forged blade.
Being a bladesmith does not automatically make you a knowledgeable heat treater.
Lastly, steel is an inanimate object; it does not have a soul! It might have "soul" but it doesn't have "a soul".
