I've not sharpened any regular kitchen knives, nor EDCs, with my Ketiped yet. I've got play (way more than I like) in the clamp bar when I flip it. One side up is rock solid, but flip it 180 and it wobbles. Flip it back and it's rock solid, again. I've had it apart numerous times, and I can't figure what the cause is. So, I purchased the TooHr model without the sliding turret from Aliexpress. Good price, I think. It's on the way. Hopefully, its four bearing and spring assembly works better. I'll have lots of spare parts, anyway.
Well, that was a bust. Either Toohr's design and manufacture of the model without the sliding turret is different, or they are making big changes to everything. Most all of the cast aluminum parts are much thinner. Cost reduction by using less aluminum? From an efficiency standpoint, I'm thinking that Toohr would likely use the same casting molds for all similar models. Can we expect smaller, thinner cast components, as well as other, cheaper, parts, going forward.
Image is deceiving; the bars are about the same length
looking down
Top of tower
Stone holder
The blade clamps are exactly the same.
The clamp bar is much thinner. The clamps, out of the bag, now slide fairly freely along the new bar, but still stick in my older bar. The LE platform, as well as my Hapstone clamps still mount fine.
The clamp support upright is much thinner. The spacing and size of the four bearings is the same.
The brass flip/rotating block is the same.
The turret upright rods, while the same diameter, are now held in place by set/grub screws, instead of female threaded ends and bolts.
The threaded turret rod has smaller threads and is much thinner in diameter, and there is no locking it in place, as the thumb knob set screw was removed from the design. There is much higher friction turning the angle adjustment wheel, and maybe that's a good thing, as it now can't be locked.
The adjustment wheel now sits on some kind of washers/spacers, and 3/16", or so, above the top of the upright rod assembly. (I have not yet taken it apart to examine.)
The turret gimbal seems the same, but the platform that it sits on is much thinner.
The stone holder assembly is shorter, and the main sharpening rod that slides in the gimbal bearing is longer. Total length is about the same.
I've probably missed other changes, as time was limited; I was told to get my
 off the counter
Bottom line: Because of the changes in sizing of component parts, what I was hoping to accomplish is limited, and regardless of what available combinations I try I still have the play, the wobble. The newest, as received, has the same wobble. One side up is solid, the flip side is not. I guess I live with it.
