- Oct 25, 2010
Actually I ate a steak last night, I used my spyderco persistance with a mirror edge. It sliced it very well. Didnt push cut as expected.
Try slicing meat with highly polished edges......it just doesnt work!!!ask any butcher what they do or try it yourself!!!
ahahha some pple on this forum are worse than kids..........get a life(thats for this guy above (PWET or smtg) ).Countless butchers I know and including myself use rougher grit edges because they cut meat better.I guess they all dont know shit.....like some pple on here say...........
I just sharpened few of my kitchen and hunting knives on belt sander with 100 grit belt and then stropped it to remove burr.Got an excellent edge that both shaves hair and bites into soft materials like crazy.Im done with high polish finish etc. basically a waste of time for me.Had all my blades shaving sharp with high finish edges ...but performance was way less than now.(its ok for wood I guess but thats all).
Good post Pwet. You cant slice materials like plastic rubber cardboard Ect. with a polished edge. You have to PUSH cut them. But with soft materials like meat, skin, tomatoes. you can slice them. Its all in the cutting technique.
I have nothing against toothy edges. I like them well. What I dont like is people spreading their opinion like its the only thing that has ever worked, and ignorance. Richard says he uses a 400 grit belt then removes the burr on his slotted paper wheel. THE EDGE IS NO LONGER 400 GRIT!!!!!!!!!! That paper wheel polishes the edge, not a mirror polish but It does change the scratch pattern. That is a polished edge. Agian i really like how toothy edges cut. But dont tell me that just because my edges are polished to a mirror that they roll in seconds and bounce off everything. A solid V of steel is appealing to me.(my opinion) So please find someone to get you a GOOD polished edge and try it with the right technique.
Rant over.
boki_zca,
I new as soon as I read your post, that you were going to be getting a ton of s**t over it, but you are right! Just because it is real impressive to be able to shave hair from your arm, doesn't mean it's a good hard use edge. How many shaves do you get from a razor, before you have to change the blade? That's because a razor sharp edge is so thin, that it doesn't last.
Let the folks that get off on constantly sharpening their knives to keep them 'shaving sharp' do their thing, and you keep your blades sharpened as you suggested, and not have to sharpen them on a daily basis. Let the indignant remarks roll off. Arguing about it will just cause hard feelings.![]()
EarlFH
Forums are funny in this regard.
Gun Forums: 9mm vs 40mm
Stereo Forums: Tubes vs Solid state
Muscle car Forums: Big Block vs Small Block
Jeep Forums; manual vs automatic
Here : It's edges, Polished vs Toothy. I wonder if the one thing that can be said for all these timeless debates is simply, Personal Preference.
i do use a worn 400 grit belt but i didnt say exactly what part of the blade i use it on did i?
i use a worn 400 grit belt and finish off with the paper buffing wheel. i cant hold steady enough to cut hairs but i can treetop hairs easily and cut free hanging newspaper just as easy.
rubiconss,
Oh come on now. You know it's not correct if it's not done exactly like the next guy thinks it should be done! Just because it works for you, just means your not as smart as you should be.:yawn:
In the email I believe you are referring to, I said that "... i looked at my 400 grit belts that i have been using for the final edge and its getting quite worn so now i'm going to keep a belt just for the final few passes to work up an edge"
I work up a burr with a good 400 grit belt and follow it up with a few passes on the paper wheels. it makes for a sharp and durable edges, as some other members have said
I have said all i'm going to say in this thread to you.
really, hillarious ...
