Well in this case it's not a coating but a bas-relief.![]()
1. I love TOPS knives, and Mike Fuller is a friend.
2. Why is it that the newbs always announce their presence by bringing dead threads to the top?
3. JimSlade, the blades are left rough so the coating will stick better. It is not rocket science. EVERY item that I have ever seen that gets powdercoated was beadblasted first, but you might know something that I don't.
STeven Garsson
Powder coating needs no texture to adhere.
The tops ones I know will remove rather easily.
This knive is more like a wedge than a knife. It almost splits instead of cuts. Carrot pieces usually just "pop" off instead of being sliced off.
So if the texture helps I believe it is in a minimal capacity.
I noticed that when battening my knife through the 2x4. It seemed like once about 1/2" of the blade was in the wood the whole board would just pop apart. Which isn't a bad thing, but it is more of what you would expect from driving a wedge through a log with a sledge hammer.
The knives are wedge shaped, generally that isn't a good idea, even for splitters. The best splitters will be curved. Only the massive ones are triangular, monster mauls and such, ~20 lbs heads. Cutting is of course relative, compare the performance of the TOP's to something like Kirk. I can guarantee that you can easily double the performance and depending on the exact grind, possibly go up to 5x as high.
-Cliff
I've done everything I can think of to get one of my Tops knives to cut better and I have succeeded somewhat but it's been a pain and it still isn't very good.
This coating offer some TACTICAL advantages:
It eliminates reflection, and colors a blade black.
It greatly increases corrosion resistance of tool steels.
My God. I actually must agree with Cliff Stamp on the TOPS knives. I have always thought he was a bit excessive in his criticisms of some knives I use and like. My first and last TOPS is the Tom Brown Tracker. For $200, expect a little more attention paid to the primary grind. The Tracker is just a nice club or anchor. Its not a knife or axe. Won't cut. Stay away from TOPS. IMO they are overpriced and overrated.Get an Ontario (Stamp hates those) or a Becker or even one of those $500+ wonder knives from Busse (if you can find one). I'd rather have a cheap Pakistani Kukri than another TOPS.
