Diamond Cut II said:The thickness of the liner make it as strong as a frame. But if that's the case, then a tanto SMF will get the job done nicely.
Cobalt said:Yes, I meant it not for flipping but EDC as well. Thinnk about it a Bali would be more solid than anything else if beefed up. No way to fail and dual pivots holding the blade. If done right nothing would be stronger IMO.
I think Bali's are illegal in many places like Ca, Mass, etc. Not sure though.
wetdog1911 said:Not here, with a CCW anyway. AFAIK it's only ballistic blades, full auto and suppressed weapons.
Blinker seems to be getting into some stout Bali's .....
Seems like Bali's would be the strongest 'broke in the middle' knife out there.
Problem with most is the blade profile which is a bit on the other end of 'utility'. Tanto's and stuff just don't float my boat.
Rob
ric0shay said:P.S I might think differently if I had a Mission MPF 1
I'm glad someone mentioned Andrew Demko, I talked to him at a show, and he explained to me that the lockbars on his framelocks have reliefs (the cutout that allows bending) that are much shallower than his competitors. I saw some others and he is right, a lock is only as strong as it's narrowest point. Many of the other framelocks have 2/3 or 3/4 of the bar dug into, what's the point of that, you're seriously reducing lock strength.samhain73 said:How about an Demko Model 1? The blade is 4.125" x .200 thick S30V, handle is 125 thick 6A14V Titanium, with a 1/4" thick 440CSS Pivot Pen! Now that's a beast of a frame lock!
Yes, I ndeed it IS a hard use knife!! I have an all titanium one.crown said:What about the Mission MPF-1. I heard that is a hard use knife.
He has also been known to be somewhat unscrupulous. Check the GB&U before dealing with him. I know he has a habit of copying other makers designs, like Jack Crain's work, for example.not2sharp said:Farid Mehr makes some really enormous folders.
Walking Man said:He has also been known to be somewhat unscrupulous. Check the GB&U before dealing with him. I know he has a habit of copying other makers designs, like Jack Crain's work, for example.
