Jason B.
- Jun 13, 2007
Edgepal,
The apex is the cutting point, EVERYTHING behind the apex is friction. The apex angle also does not need to be the complete bevel angle.... And edge geometry + hardness = the edges ability to withstand your uses. The angle itself is not the sole factor.
The angle wobble again is throwing you for a loop. When I sharpen and have 5 degrees of play I still end up with a 40 degree inclusive bevel apex with a 30 degree inclusive shoulder angle. My wobble is from the center of the knife not the sides so its rare my angles at the apex are different. In the past several months I have checked my edges with a CATRA edge protractor, out of the 300 or so times I used it I was only off by 1-1.5 degrees with maybe half a dozen knives. Not bragging just stating evidence in what I have discovered with my own sharpening.
Lagrangian,
You can grind a groove in a blade in a few short passes just by having your fingers in the wrong place applying pressure. Not a groove that's all to visible but enough to severely distort the edge if you sharpen below say 10 microns in abrasive size. So, if you touch the work piece in any way while grinding you must know how to "map out" the pressure points needed or you end up with high and low spots.
It's not the flex of the blade that changes the contact point its the opposing pressure. The work piece could be a few inches thick and I would be able to pinpoint where the grinding took place on the opposing side.
About the edges, edge 1) would be a noticeably better cutter and slide through material smoother with less possible micro chipping at the apex, its a total of 6 degrees thinner again geometry wins. Edge 2) would have wedging problems on thick materials as the Sharp shoulders would create a high load of friction before the transfer to the blade grind. Sharp angles don't flow.
Lagrangian,
