Knifenut1013
We disussed for a year ago in this thread if it is possible to grind an angle as low as 1 hundred part of 1 degree. It is.
I did it for some time ago. It was in fact rather simple to do. I used 30 micron diamond sharpener to do it. This photo shows how it looks:
I first grind the total edge as flat as I could do it. I do not know how flat it is – I like to sat perfectly flat – but nothing is perfectly flat so I must try to explain how flat it is – you can see two surfaces, the smaller surface have I grind 0,01 degree higher then the first surface. That means that the first surface is flatter then 0,01 degree and we must measure it ina few thousends part of 1 degree.
I use Norton well used diamond sharpener in 30 micron to do both surfaces. I have grind the diagonally in different angles to make it possible to see them.
I use my sharpening tool EdgePal Chef to do it. It was easy. (Everyone who have a Chef can do this – and also repeat it). There is allways 28 cm between the cutting edge and the pivot point with Chef. The pivot height are demanded by a nut on a long vertical screw. I change that nut 1 seventh of a full turn – 28 cm from the cutting edge, that is 0,01 part of 1 degree on the cutting edge.
What I learned is that I shall do it again, but now shall I change the angle only 0,005 degrees, that is half of 0,01 degree. 5 thousends parts of 1 degree, that is my next goal.
Thomas
Thomas
