Hey electrically knowledgeable people,
the new house has an 8x16 shed out back that is just at 50 feet from the nearest plug (based on stepping it off). I'm thinking I'm going to buy an extension cord, run a window unit (probably 8000 BTU), a florescent shop light, and one tool (grinder, drill press, etc.) at a time. Will that possibly work off a 100' 12/3 extension cord with a heavy duty outlet strip? I'm concerned a 50' would be just a bit too short. I can't find a 75'. And chance it will work and I won't blow the circuit time and time and time again?
Thanks and Happy Independence Day all!
At less than 200 sq ft, you could get by with as little as a 5k or 6k BTU unit, IF the shed has any insulation at all. If it is NOT insulated, in College Station during the summer, even 8K might not be enough.
Wow... We just jinxed me it seems...
My pump/well stopped working... No water to the house. No pressure at the tank on the gauge. No water out the hose directly at the pump.
No breaker popped or tripped. I flipped the breaker back and forth to try resetting. Power is going to the pump. But the pump isn't working. The low pressure switch box doesn't have a reset arm sticking out to reset. Tried the overload restart. Nothing happened.
Worked fine earlier today.
Well, that sux. Hope you figure it out soon, before y'all start attracting flies....but seriously, I hope you figure it out. Might actually be that the pump itself has burnt out. Funny how no one thinks about water coming out where we expect it to until the SHTF....although in my house it's usually that water is not exiting the house the way I expect it to....I don't know which is worse - but both situations are NOT optimum.
Id be fishing from the top step and fryin them up on the roof.![]()
