Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
- Aug 20, 2004
Dustin,
I'm afraid you don't understand the terms used for steel. Air hardening, oil hardening, and water hardening are terms used in industry to refer to how the steel is processed commercially. It is not specifically an indication of what it will harden in.
If the steel you have is 1095 ( a spring steel technically, but often referred to as a tool steel), it will harden in oil if the oil is the right type. Just sticking it in a quart of Pennzoil won't tell you much. Conversely, you could stick O-1, A-2, 1095, 1050, and W-1 in a bucket of water, and they would all get hard. That wouldn't tell you much either (beyond the fact that there was more than 30-40 points of carbon). Then there are the stainless steels that are often referred to as "tool steels". They won't get hard in oil or water, unless heated to 500-600F above non-magnetic.
I know that the person said "tool steel", but that means different things to different folks, and I have seen a lot of machinists and others who should know better call all precision ground bars of steel "tool steel".
The choices of what your piece of your steel could are be endless, and many will make a great knife....with the right HT....., but a wonderful steel, that is given the wrong HT may make a poor knife. If it was M-4 it can give you a fantastic hard blade, but only with the right HT, done by the old "non-magnetic and quench in oil" routine, and M-4 won't even get hard.
Stacy
Stacy
