- Apr 7, 2006
I believe the blade is actually bent on this knife, but either way it results in the tang rubbing on the scale and the tip sitting off-center. I understand that knives are meant to cut stuff, but when a knife costs $150, you expect a high degree of quality and precision to come a long with the utility. I just feel that Spyderco did not listen to me when I told them a defect in a nice knife bothered me.
It may not look very off-center in the pics, but that is because the tang of the blade is resting against the scale and does not allow the blade to travel any farther over. If this is in QC specs, I have a lot less respect for Spyderco as a company.
I understand there are a lot of Spyderco fanboy's on this forum, and I can already see the subtle attacks coming because I did not adore this knife for what it is. I am not attacking Spyderco's design, just the fact that they let a sup-par product through QC and now won't make it right.
If you measure the length of your blade (or know how far down the handle it sits when it's closed) and send a knife in for sharpening, it will usually come back significantly shorter. I've heard of people having more than a 1/16" ground off of Sebenza's even. I believe they use sharpening Jig's, so no matter how damaged the edge is you end up with a clean grind. The disadvantage to this is that it removes a lot of metal. I have had this happen to knives I sent into Benchmade as well, I heard that they get shorter, and so I look for it now.
The Native IV is a lockback, so lock pressure cannot cause a misalignment. I find a bit of misalignment in liner/frame locks to be acceptable because I understand the dynamics of the lock. When a lockback is off, something is not right.
I'm not trying to sound snooty, but this is no Leek. This knife retails for around $150 and is now discontinued (that's why I can't get a replacement). I like this knife because it features excellent materials and workmanship (ideally). I have many knives to cut with, but once you pass the $100 mark, you are also paying for a healthy dose of quality and workmanship when you purchase a knife. I obviously did not get this knife for the sole intention of being able to cut stuff, I have Mora's and Opinel's for that.
It looks very slightly off-center. Not sure if that's what you mean by bent. I guess it's within their specs. Look at the Caly 3 - that doesn't have any washers so the blade gets rub marks immediately. So those marks aren't inherently a problem.
Also when you say they ground off a 1/16" of your mili blade, you mean when they sharpened it it ended up that much shorter? I find that hard to believe.
That's caused by the liner, not a bend. It's is a common problem with a lot of liner locks that has a simple fix.
I hate to say it, but it looks fine to me. Nothing man made is perfct. I have a Kershaw Leek and its blade is much more off centered than your knife.
