- Dec 2, 1999
Bruce Bump, I see you are one of the Aspen Green lovers on Bladeforums too.![]()
Ron, good call! Yes I've found that Burr King uses Aspen Green so now everything is that color in my shop
Bruce, I figured it to be about 2,670 sfpm. I wouldn't put my life on those calculations tho. :foot:
With the 1700rpm motor spinning a 2" pulley to drive an 8" pulley, that should give around 425rpm.
Then the belt surface feet per minute= (RPMxIPR)/12... so (425x75.4)/12= 2,670sfpm
I wouldn't be surprised if someone comes along and tells me I'm completely wrong...
Re the green--- In my industrial operations books, they say that green color helps the operator focus on the task and not the machine itself. I'm not sure how that works, but it must, because there have been an awful lot of companies that painted their tools/equipment John Deere green or some slight variation of it.![]()
I would think cost would be prohibitive.
Compensating for something?
That thing is pretty awesome, Ill have to stick to my 14" for now.
-Josiah
I would think cost would be prohibitive. and the fact that surface of the grind wheel spins faster as the wheel wears down. multiple grits would require multiple wheels. on practical machinist. com, owners of large powerful stand grinders make it sound like the belt grinder has replaced the bench/ stand grinder.
Thanks Nick,
Would you please do the math with the same rpm of 1700 but with a 2" drive pulley, 4" driven pulley and the old 14" wheel? I hoping the surface feet per minute is close to the same. I loved my 14" because it spun at a nice controllable sfpm.
1700rpm x (2/4) x (14" x pi 3.14)
= 1700 x .5 x 43.96
850 x 43.96
= 47 366
inches per minute
= / 12
feet per miniute
=3,113
just to show the work because sooner or later somebody else will try and caclulate this.
= 1700 x .5 x 43.96
850 x 43.96
= 47 366
inches per minute
= / 12
feet per miniute
=3,113
just to show the work because sooner or later somebody else will try and calculate this.
Ok so if I want to match the sfpm of the old 14" wheel I need to change the driven pulley to what size?
3113= (1700 x (pulley ratio you need ) x (24x3.14)) /12
3113x12 =1700 x (pulley ratio you need ) x 75.36
Dammit Bruce, I had to find a pencil to get that one.
ratio of .3
so if your small wheel is 2" then 6.6" is your other driven pulley
double check it
1700x (2/6.6) x (24x3.14)) /12
=3200 ish
There is rounding errors in there
a 6.5" would be really close
Instead of buying another big expensive pulley to get the right ration, I would buy a larger pulley than the 2". This will be cheaper in the end and get the same ratio.
