Very nice work!A pocket holster that I made for a Ruger LCR. It's made from horsehide and is completely hand-made. I used Sinnabroks pricking irons, and hand stitching was done using Ritza Tiger thread.
Thank you.Very nice work!
I used a pricking iron with 3.85 mm spacing on that holster.Dave-
Your work is absolutely flawless. Could you share the thread hole spacing on your work? Thanks
Whipped up a quick sheath for my survival axe. I think I'm going to add a belt loop.
beverage vessel sleeve, (aka BVS) was laser engraved today by a pal of mine. Gotta stay hydrated in Hotlanta!
Thanks! I got the survival axe blank from Jantz Supply. And I made the handles from spalted hackberry.
Looks great!beverage vessel sleeve, (aka BVS) was laser engraved today by a pal of mine. Gotta stay hydrated in Hotlanta!
Good job. Very nice set of scales.Thanks! I got the survival axe blank from Jantz Supply. And I made the handles from spalted hackberry.
Thanks!Looks great!
Ya bet and ya did a nice job with em too! While I've never made an axe I think I would of been tempted to use corby's or Loveless bolts on the handle. Maybe help with impact I don't know?Thanks!
I knew the correct term was scales for fixed blade knives. I've seen "handles" used for folding knives. Wasn't sure what to call them on an axe.Ya bet and ya did a nice job with em too! While I've never made an axe I think I would of been tempted to use corby's or Loveless bolts on the handle. Maybe help with impact I don't know?
I used Loveless bolts on this semi skinner:I knew the correct term was scales for fixed blade knives. I've seen "handles" used for folding knives. Wasn't sure what to call them on an axe.
I need to explore the Colby's and Loveless bolts as well. I only use a woodworking disk/belt sander and it tends to sand metal pins less than the surrounding softer material. Tough to keep the pins flush. So I have been using a softer (wood?) pin. Bolts would be a lot better. And I suspect that bolts would be better for impact than the softer pins I'm using.
