Whacha Been Up To......
@RayseM
Stay with it 👍 Looking better and better
I like your style!!
Digging the shackle love :)
Looks beautiful and rustic, great match for the knife!
Thank you all. Appreciate your encouragement. I'm having fun and that's important too. The shackle is a natural as I have quite a few from the boats and boat yards in my life. I am looking to upgrade to a sleeker look though. And, yes, I LocTite the threads.
Not to mention the mini bolas that can be used to catch squirrels and similar in a survival situation 😉
Partially redid the frog of one of my CVA bowies, and also shortened and re-riveted a belt I got recently while I was at it:
A neck sheath for a yard sale knife (which is actually a repurposed table knife)
First time double stitch lacing. Going around the asymmetrical point got a little funky. Something to consider in the design phase of the next one.
I think it’ll do. Now to polish up the bone handle a bit.
Odd, for me the photo is only showing when i hit reply
It is a rare time that I make a fixed blade sheath, just not something that I'm keen on making, rather do folder sheaths or slip sheaths more. But this one needed a bit better sheath if I was going to be carrying it around the property. And since there wasn't a guard I didn't do a wrap around as without the guard to hit against a cam stop I felt it wouldn't hold as well. So I made a regular type sheath, sewing it all the way around...a LOT of holes! And I am usually pretty good at guessing how long a thread I would need to sew something up, but this one was close, ended up with about 4" of thread on each needle !!! that is cutting it pretty close!
I used a stitching prong to start the stitch spacing as well as getting a hole going, then I used a dremel with a 1/16" drill bit so the hole it made wasn't too large. Even down around the blade area the three layers of leather were too thick for my stitching prong to get through and of course up at the opening, there is a lot of layers to have a little wider opening. The spacers are on top and below the center layer of welt, and at the very start of the opening, the belt loop portion was skived down and glued down to the sheath and the welt was placed just on top, making it fixed in place.
Being so thick, I was going to use my bandsaw to trim off the outer edges of the sheath but I decided to try a leather knife that my friend @Matthew Gregory cooked up for me from a pattern that I had Tony Bose make for me years ago, but this time in quite thin Magnacut material, quite slicey ! thanks again Matt !
Untitled by GaryWGraley, on Flickr
The knife is nice and snug inside this sheath and the handle rests just about mid level of my belt so it doesn't poke up at me.
G2
G2
Very nice work as usual :thumbsup:
One guy doing sheaths on youtube mentioned a rule of thumb he used, thread length = 7 times (I believe) the length of the stitching, but obviously that depends on thickness and your sheath is pretty thick... It wouldn't be fun to run out of thread the last few stitches! I imagine I will use some rather naugthy words when it happens to me, because I am sure it will at some point ;)
@Gary W. Graley and @Lorien, in your latest work above you make your sheaths without folding the leather, instead stitching layers all around (excuse this non-native-english leather amateur, I assume there a correct terminology for these two basic sheath types?) I'm planning to do a sheath for a ka bar, specifically the 1271 fighter, which came with a rather poor sheath. What would be your, and other thread contributors, like @RayseM 's et al, suggestion for such a knife, considering the massive guard et c? The basic ka bar type leather sheath with that "reverse" belt loop perhaps? I'm unsure, and not totally convinced I like the "suede" side up on the belt loop 🤔
@baxtrom for that type of knife I would do a similar type sheath, and make the welts thicker so that gives you a more open throat of the sheath to make it easier to return the knife back into the sheath.
And yep I have heard several ways of measuring thread, in this situation it would not work as well because of the very thick sides that are near the opening required more thread. My rule of thumb is more is better!
Worse case if you ended up not having enough, you just cut the thread on both sides and start with some new thread a few stitches back so that you will sew over the ends and lock the first thread in place.
G2
@Gary W. Graley - beautiful work. Have to ask - what is the weight of your leather and does that determine the stack layers of your welt - along with the handle thickness obviously? Are you only using 5 or 6oz? Love that leather knife. It obviously works very well. I know you can sharpen an edge to perfection but the I would not have guessed that that blade shape would be that capable at the task.
@Lorien - Your CUTLASS is awesome and the sheath is a worthy partner too. All those screws intended for carrying loop options? I wonder what you envision.
@baxtrom - I'm not one to advise on thread. Pretty much use one type and one thickness for now. Haven't had the courage to explore to far afield from what works now. Have been thinking about it though as I get ready for a supply update. I will read the replies/advice as intently as you.
The leather is 9/10 oz so it’s fairly thick and on this one I wanted it a to be not quite as thick as the handle so that the top layer provides some compression and aids to hold the knife in the sheath.
G2
thanks bro! I didn't think through the various carrying options for this sheath, since it was a rush job and I really just needed something safe to put the knife in, but yes those holes the screws are in are there just in case I need to built something down the road for it. The screws are there in order to provide a little extra protection for the stitching, although there's plenty of welt to do the job
forgot to post a vid;
