That is looking really good. Definite step up from the first. What would you do different next time?This is my third one of these, definitely turned out better than the others.
Thank you!That is looking really good. Definite step up from the first. What would you do different next time?
@duramax Very nice my friend, very nice!
Definitely make sure the molded part is more square with the edges and stitchline (you can’t see it in the picture but its a little angled), also I think I would dye my next one.What would you do different next time?
Yes sir, I’ve got a couple ideas. I’ll probably type em in the morning. Most of my typing is early am, coffee time.Thank you!
Any other improvements I should consider for next time?
Something like this is what I’m wanting. Again, this is for a knife made by Flat Rock Forge. Need to know if you can work from measurements or do I need to send the knife to you. Thank you very much!
Sorry didn’t have time this morning. We’ll catch you tomorrow . I won’t forget.Thank you!
No worries; I appreciate it!Sorry didn’t have time this morning. We’ll catch you tomorrow . I won’t forget.
Wow, thank you. It haven’t even ocurred to me to leave the bottom panel oversized until after stitching, but that does seem wise!Okie dokie. Here's some ideas for you.
Are you leaving the bottom piece oversized and are you trimming flush to the top after sewing? If not that would certainly help with the alignment. You only have to match up the top edge to the premolded front. Thats a lot easier than matching up four sides. If you are, than are you using an adjustable stitching groover with a fence to keep your groove consistent to an edge?
Now I don't do a lot of molded stuff like this but I would have one design concern. Seems like there is quite a distance between the bottom of the multi tool and the bottom stitch line. Will, in some years time that bottom molding get soft from use abuse and the weight of the tool? Seems like it might. Is your design unnecessarily deep? If the bottom molded part was closer to that stitched edge I think that would be stronger.
Yesterday would of been a good day for you to hang out in the shop because I was doing a lot of what I would suggest to help ya with this project. I work in batches and make several things all at once. I almost always leave the bottom piece of a project oversized so that I am only prefinishing and having to align up the tops. In this pic I have 6 Leatherman sheaths to make up, a holster and have already sewn three slip sheaths for kitchen knives. The slip sheaths have a simple welt on the bottom side other wise the construction of all these guys is very similar. I have 12 other sheaths to do too but I tend to divide batches up into groups of what is constructed similarly and these are pretty much all the same.
I'd already sewn up the three slip sheaths with red. I sewed them separately cause the red thread was already in my machine from my wife using it on a purse so I did them before changing back to white for the others. After sewing I trim off the excess of the oversized bottom pieces.
No matter how sharp your knife is and how careful you are there is gonna be some unevenness. Your sheath is showing that a little.
So whats a guy to do? Sand the edges. Now I was pretty experienced and had hung out in several saddle shops quite a bit before I ever heard of sanding an edge. Its a handy deal. You can use foam sanding blocks or just sandpaper. Lil more later.
I do use an adjustable stitch groover, but the molded part of the leather gets in the way of the adjustable arm, so I used a scratch awl to mark my lines and then went back over them with the stitch groover with the arm removed.
Yep, you are correct. I have seen ones like the one on the bottom; I may have to look into getting one of those eventually.I'm assuming the groover you have is the same as the one in the top of this picture. The one on the bottom will solve the arm getting in the way problem. I also find it works better on projects where you don't have to worry about the arm getting in the way. It's just easier to follow the edge.
O.B.
Untitled by GaryWGraley, on Flickr
My friend looks like your stitching is doing great to me. Very nice work. Bag making is a whole different deal isn't it?
Gorgeous my firend, knife, sheath and pics! Are you able to do the red cross first before ya have more time into the sheath if it doesn't work?Needed a nice slip sheath for my new Swiss Army Cadet folder, the red cross is always tricky as leather does like to bleed and the first go at it I had to scrap, no saving it, but this second one came out better.
The knife is a 2023 limited edition from VIctorinox which sold out pretty quickly and it is an amazing bit of work.
2023_ by GaryWGraley, on Flickr
G2
That looks great! Some great work being shown here today.Sent this one down the road recently.
Yeah I recently tossed a fully carved sheath ready for molding to the knife. It happens but dang!Thanks Dave, the sheath was embossed dyed and glued but not sewn up at that time, so at least I didn't have time spent on the sewing parta small savings I'd say. It is a rounded surface along the edges of that cross after I emboss it, so even being SUPER careful, a drop of dye can slide off pretty easily. I tried several things to try and salvage it but, it grew worse and worse so just cut my losses...actually cut the sheath up lol...and moved on.
G2
Nice job GaryNeeded a nice slip sheath for my new Swiss Army Cadet folder, the red cross is always tricky as leather does like to bleed and the first go at it I had to scrap, no saving it, but this second one came out better.
G2
