bigmark408
- Nov 13, 2006
Only when you folks have held a Kiku Matsuda will you know what a convexed grind/edge is.
It's good for choppers (slightly stronger & less prone to sticking) and easy to maintain, easy to learn, somewhat forgiving of technique. I have a small knife with a very thin convex edge and it cuts very well. But so do my non-convexed edges. All personal preference.
I think the discussion should be more about the optimum edge geometry (for a specific task), rather than worrying about whether the edges are rounded. I doubt there is much of a practical difference assuming the basic shape is the same.
I put convex edges on my hatchets. I've noticed better edge retention even though I made the bevels higher than before, but I push into the belt pretty hard when sharpening to make sure it thins it out but puts on a wide inclusive angle aswell for better edge retention.As I said-cheese knives and hatchets.
I kinda thought Phillip was just being a little snarky, and this is what he meant about it being a good thing that a straight line from edge to spine can fit in the geometry.
You can do it with any grind, even chisel.
I showed there is infinite number of such straight lines that CAN'T BE DRAWN INSIDE the non-convex shape.Nor can you show me any of your blade profiles that I can't draw a straight line from spine to edge inside your geometry. It is a good thing, though.![]()
That is a correct concave geometry. What is the edge angle on that blade? Ideally it can approach exactly zero degrees (but now quite, in Euclidean space). Do you have an actual knife that matches that geometry? Do you have a radiused stone or wheel to achieve it? If you do, please tell me your secret.
You are contradicting yourself.My straight razor looks similar, but is not the same. It is actually convex from edge bevel to spine. The ideal razor is perfectly flat from spine to edge (with a hollow in the middle for flexibility while retaining the weight and stiffness of the thick spine). This is not quite possible with actual sharpening equipment. The stone eats at the edge slightly faster than the rest of the bevel. The edge angle ends up just a bit greater than the ideal flat bevel.
First I didn't use "my" definition, it is general definition of convexity. Second, your conclusion about convexity of drawn shape is wrong. It is not convex.Here's what a real knife edge looks like.
This is a hollow grind with secondary edge bevel. On the right are two tangents that define the overall geometry from edge to spine. By integrating those lines, you develop a curve that defines in a single equation, the shape of the edge. That curve has convex geometry. You can easily prove that (using your own definition) by the fact that a straight line from spine to edge is inside part of the bevel.
That's what I'm saying, if we accept that thinner grind leads to sharper knife.Is afullconcave (or flat) grind sharper than a convex? Of course it is.
I didn't say anything about that and frankly I do not know why you think I didIs it useful for knives? No. Not until we find steels capable of supporting edge angles less than about 10-degrees inclusive (depending on the size and thickness of the blade).
Believe me, as soon as we invent a material capable of it, I'll be right on the incredibly sharp, super-thin, truly-concave blade geometry.
I agree you can flatten a convex and thin it and then thin a flat by convexing. The real question is witch one do you stop at before the edge is too thin and week?Really some outstanding discussion. Recalling when this subject came up in years past on BFC, it certainly didn't seem that near as many people had given this so much thought.
Ultimately, it comes down to the fact that, if you were to take a V-grind edge, whether single or multi-bevel, and round off just the shoulders between the bevels, you would wind up with a thinner overall geometry that would cut better. But then, if you were to take that blade and thin out the convexing behind the very edge, again making it a single or multi-bevel, you'd have thinner geometry still, with better expected cutting performance. You could do this, convexing then flattening, back and forth, each time improving performance, until you exceeded the limits of the steel and the edge/blade became to weak to hold up.
Which is best?
I'll disagree with this a little I think that shape, thickness and finish are all important in how well a knife will cut. And really isn't being convex, flat, or hollow a description of the geometry?IMO it has almost nothing to do with whether it's convex or V-grind, and everything to do with geometry and cross-section of the blade.
I suppose that would all depend on where you started, in terms of the blade/edge's original thickness, and how much you removed at each step.I agree you can flatten a convex and thin it and then thin a flat by convexing. The real question is witch one do you stop at before the edge is too thin and week?
Yeah, I didn't word that too carefully, should have just said cross-section.I'll disagree with this a little I think that shape, thickness and finish are all important in how well a knife will cut. And really isn't being convex, flat, or hollow a description of the geometry?
So long as nobody says something is a "teachable moment" ...There's that word again!![]()
While that's pretty impressive, I'm not so sure that it really proves anything about a convex edge. Further, it looked to me like the middle to middle upper part of the knife did the chopping, while the upper curved portion was used to shave at the end. Granted the video was really choppy and kept freezing in the player, so maybe the curved portion did touch the wood at some point.
I think that steel (1095 tempered to 63 - 65 RC) probably had a LOT to do with how tough the edge of that blade is.
Brian.
On Sept 1,09 I was at Richards J and I used his K2 knife to cut a piece of 4" elm into with that knife and I used the middle of the blade and I could shave hair on my arm with the middle of the blade after cutting the elm into. And I have never seen that done before. So I would say that his convex blade is a good one. And I don't plan on using any knife to chop wood in the future, I'll leave that to a axe. And I beleave his knife is made from 1075 steel.
Richard starts off the convex edge with a belt sander and takes off the burr and polishes it with paper wheels, the fine wheel doesn't take off enough metal to make it concave.Doesn't the paper wheel system produce concave edges? concavity = 1/convexity so they are opposites.
I agree 1075 makes a wonderful chopper though.
The advantages of convex are probably negligible for smaller knives seeing light use, but for high-impact applications like chopping, the convex-style geometry provides a good balance between penetration and strength. Heck, hatchets and axes are typically convex in profile (with exceptions for more specialized uses, like splitting).
