Used my CF DT Small 21 to strip some wires and mend a connection, then cut stray strands that my kitten has lifted from the carpetI've been running my edge based on some discussion with unit some month prior, regarding high polished edges that retain considerable bite. I've done it through his suggested grit progression and strokes and am never let down with how disgustingly sharp the edge gets and stays.
Sure. Start at a low grit and polish up to 1000-1500 grit using alternating strokes. After, go straight to your finest strop compound (for me this is 20k grit honing oil), skipping the the in between stages. 5 strokes on one side, 5 on the other, 3 on one side, 3 on the other, 2 sets of 2 strokes per side, then a few alternate strokes to finish off. Should come out sharp enough to tree top, and push cut with ease, and retain enough bite to slice aggressively.Could you share that info?
Thanks.
Thanks, my friend. I am just following the steps you outlined for me, nothing more. Credit where it is due. My edges have been very sharp for many years but, in my opinion, not optimized for performance (over polished and mostly good for push cutting)Harris, I am glad you found a good combination that works for you.
A good edge is nice to use.
Not a problem at all. To add, I am running a 34 degree inclusive profile (semi convex).Great! Thanks for the lesson.
ok, well some filet mignon with.....you guessed it.....rice-a-roni...
[/URL][/IMG]![]()
Wow. That picture scares me. I can't bring myself to use my knife on food. Terrified of rust.
Not much of a worry with S35VN, pretty good corrosion resistance IMHO.
I cringe to think of the sharp blade sliding against a porcelain plate. Wouldn't that dull it quickly?
Tim
