- Mar 28, 2013
No, epoxy baaaad. You can always fit in two pieces of wood shaped to fill the gap and wedge that. Should have a similar compression effect.
^you could fill it with epoxy?
Have you considered making a single wedge to fill the back of the eye and then using a shorter main wedge? I have to wonder if the maker didn't intend for this axe to have cross wedges rather than a typical wedge. Is the eye wider top to bottom?
Funny thing I seem to recall Nick having the same issue with his last hang. I've yet to come across such an eye.
I guess if you epoxy it it means you cant reuse the haft (easily), and there will be more prep work involved (removing / filing out epoxy) if you were to ever re hang it, but its not the end of the world.
Really its the purists who would say don't epoxy it as an axe can usually be hung well without it, so it just makes rehanging it more of a pain. But I spose epoxy has its place. Many axes, mauls, sledges etc come standard with some form of epoxy in the eye.
Its not the prettiest most traditional solution but its a solution non the less
Carved this handle from a 26" hickory handle blank from Thrane, black walnut wedge, Spiller 3lb jersey head. Just finished it last night, well finished for now, I tried carving pieces of wedge to fill the space in the eye but it ended up being the most frustrating thing I've ever done with an axe. The eye constricts on the inside and then widens at the top so unfortunately the eye of the handle ended up being a lot smaller than the top of the eye of the axe. As I was lightly tapping the pieces of wedge in they broke off below the opening so I couldn't pull them out, figured I'd just pound them down and put more on top, the main wedge broke as I was doing that. So I ended up having to drill out the original wedge and rehanging it. I'm keeping this axe as a personal user so after last nights fiasco of trying to fill the gaps I'm not sure if I'm going to try again, I know I'll get shit for it but it's hung super tight and having already drilled out the first wedge I know it's not going anywhere anytime soon. That being said I'm a perfectionist when it comes to this stuff, especially when they're my own personal users, so it's bugging the shit out of me that it's not perfect but I'm not sure what else to do. I may eventually try again but I have a feeling the pieces of wedge will just keep breaking off when I try and tap them in, and it took me like 2 hours to carve/sand them down to the correct shape.
That is a nice looking handle and a nice looking head. I wonder if they are meant to go together?
Your wedge would come out pretty quickly if you wanted it to, maybe to pair that head up with a handle with a tongue that better fills the eye.
If you carved it from a blank then I wonder, did it look short to begin with? That does mean you had control over the initial shaping.
Dissembling it would allow for some pictures to see what that tongue looks like to "fit" in the mouth of the eye and leave a space like that.
Like I said, it's a very nice looking set-up but it kind of looks like if you used it much it would crush that wedge in the back and come loose.
That handle looks like it wants a boy's axe on it.![]()
Yeah I get what you mean, I'll keep it as a back up option but will probably try and fit wedges in it first as I'm a perfectionist when it comes to my personal axes haha
I would try something like pine or some other softwood that will better conform to the space you are trying to fill. Make sure the growth rings are running across the thinnest section to help preventing it from breaking and use something wood to drive them in rather than a hammer. At least that's how I'd go about it.
If it makes you feel better I'm on wedge number 4 on one of my axes currently. For whatever reason it keeps spitting wedges. I refuse to use metal cross wedges and glue, guess I'm a purist or whatever. Anyway we all have issues with hangs from time to time, don't let it trip you up.
