. . . I have an 8'' bench grinder and try to stay away from it for all the obvious reasons.
Rick, IMHO, you've got it. With that attitude you will never burn anything.. . . and not in such a hurry to get a job done. . .
Could you please provide the list of these "obvious reasons" for not using a bench grinder? They are not known to me.
I think you are saying that use of a bench grinder has limits. :thumbup:I'll take a stab at this... First, it takes off a TON of metal/material. Second, it can get hot enough to ruin the temper. Ideally, any sharp tool/blade would be taken out from proper storage, checked for sharpness, used, cleaned, checked for sharpness at the end of the job, re sharpened if needed, and then properly stored. That said, there are circumstances where brute force (grinding wheel) is nice --like starting or re-shaping an edge on an old, neglected or abused tool. But it should be a start, and then finished properly, similar to how we would use a rasp or draw knife to start shaping a haft and then finish up with sandpaper.
True Value had them on sale for 6$ and it gives me a fairly big flat surface to rough things out. I have an 8'' bench grinder and try to stay away from it for all the obvious reasons.
1215 this is where "the obvious reasons" started and has been since addressed, I think you took it a little out of context.
Rick
I'm fixing up a nice, but unstamped brush axe/ ditch blade for a family member. They said it wasn't working well, and it wasn't. It was rusty and dull. I dropped it in vinegar, and then wire-wheeled it followed by WD-40. I put a thin green/grass edge on the inside curve edge, and a more obtuse but still shaving sharp chopping/root/dirt edge on the back. I saved the handle, painted the brackets, and will have to get new hardware as I had to cut the old bolts off.
It'll be a slashing machine when I'm done.
Now I need to figure out how to protect these edges as sheaths for these aren't readily available.
I, for one, would like to see it when you get it finished![]()
