- Mar 3, 2022
Yes, I have had an Edge-On-Up PT50A for a couple years and I love it. First thing I do when I get a new knife is test at least five spots along the blade. There are some surprises.1. The PT50A is more fun than a pie fight. Quick to set up and not difficult or expensive to operate. I think this device will help me figure out problem edges and greatly refine my technique and choice of grit progressions and sharpening tools.
Next time I find a dull edge, I will start testing after each grit, which I understand can be very telling. I recently read a post where a fellow stated that his scores peaked in the middle of his progression, and started to get less sharp with succeeding polish stages. That right there is good to know, and worth the price of the PT50!
Nice work.Finally got around to reprofiling my 15V Mule. Unfortunately it came with a pretty sizeable burr so needed sharpening before use. I'm on nights so it was a bit of a quick job, still turned out decent enough for about 25 minutes. 140 grit Atoma for the rough work, then 400 grit super vitrified diamond stones to clean up the nasty scratch pattern from the Atoma and raise a burr. 1000 grit super vitrified diamond to finish deburring and set the microbevel. Finished on a strop with 1 micron diamond.
That looks like a pretty cool idea!I repair musical instruments, so I always have one of these small files within lunging distance. The safe edges are very useful!
I got in the habit of using one of these to rough-in the heel on blades with no choil. I can get a very crisp edge where the blade meets the ricasso with a few strokes, then blend it into the rest of the blade with whatever stone I am using. It is pretty quick and leaves a neat, effective heel.
The files are pretty well screwed for fine instrument work after this, though!
Those are some inspirational BESS scores, LR! As a newbie to sharpening, I would be interested if you ever tested the edges between stages, as you work through your progression.
LR, those fat spots next to the ricasso also prevent the stone from lying flat against the blade until the stone is completely clear of the fat area. That bugs me, as I think it costs sharpness and straightness for about the first 1/4" of the blade. I use the steel files with the safe edge to rough in the fat area, and I finish it with hard Arkansas files I get from a gunsmith's supply shop. Once I get the problem area level and square with the rest of the edge, it can be maintained for a long time with your typical bench stone.
I look forward to your detailed posts. My scores are about 50 grams higher than yours, and I'm getting useable tips from you!
It looks like I may have been neglecting the stropping process, using one stage of a less-aggressive compound. I think I will try a few more stropping stages and see if that starts getting me below 150 consistently.
Person: Hey I heard you sharpen knives for $xx, I seen Joe's knife, I want mine like that.
(Joe had a $250 knife that was pocket candy, never seen work it's life)
How's the carpal tunnel feeling today?Person: Hey I heard you sharpen knives for $xx, I seen Joe's knife, I want mine like that.
