They're 3V? I didn't know that. Thank you for the correction. :thumbup:Agreed. Fehrman's are 3V which would lead me to believe they would perform better than S30V with the same reprofile job and at the same edge, but as compared to INFI.......
Good post Jaxx. Fehrmans are CPM-3V.
Maybe I should invite Vassilli to the next one of our chop fests since he is in the Bay Area. That way he can get a different perspective of INFI instead of talking it down here on the forums based on some crazy thin edges.
Jim,
The edges that I put on are not much different than yours. As a matter of fact your convexed edges are what inspired me to put them on my knives.
Here is a little hintTake your edge down to roughly about .032-.028 before doing the final convexing to zero. The ideal thickness will vary depending on the angle and thickness of the primary bevel. Through trial and error on multiple large choppers I have found that this is about perfect for all around heavy duty wood chopping. Concrete and metal is another story and I won't comment on that as thicker would be better in those cases.
I have gone down to .025 and got crazy deep bites. But that edge would sometimes take rolls if I use full power strokes and connect with knots in the wood.
I have taken it even thinner than .020 and got multiple large ripples when I hit the knots really hard. This happened when I tried to push the limits of my FABM. That is the reason why it is constantly evolving
Note that I am only referring to edges on large choppers that are capable of serious momemtum and power. Smaller knives that cannot generate that sort of force can probably benefit more from a thinner edge.
It's not a factory grind. I know Vasalli owns a GW and he's re-profiled it so I have no reason to believe he's not telling the truth. Plus he's a pretty upstanding guy here...
Based on past experience from what I have seen from him, I disagree. He's gone out of his own way to misinterpret his own test data in the past to make INFI look bad. Whether he intends it or just doesn't know how to interpret test results is irrelevant.
best i can tell, he is the only one who can interpret his "data".
Ive never been able to make heads nor tails of it. And the edges he puts on knives would fold cutting a birthday cake.
and have a nice drink.:thumbup:
I grind my edges really thin also. Keep in mind, when I grind them thin, I also thin out my Opinels. No joke. But when damage occurs, I don't blame anyone, I just figure that I've found the limit and adjust from there, depending upon what I want the knife to do.
The trick is finding that balance of cutting efficiency and damage. I usually experiment until I get to the point of damage that's unacceptable, then back off a little. Actually, instead of backing off, I put on a micro bevel that generally takes care of problems.
Every steel has it's limit. INFI is definitely better than most for resisting damage.
