- Dec 9, 2005
The white sharpmaker stones seem to give me the best combination of push cutting and slicing edge sharpness and retention on my knives for my light duty uses, while I use the corners of the brown rods for more cardboard intensive work. The steels I use are AUS-8, VG-10, S30V, and the steel used in Byrd knives.
The sharpest knife I had ever seen until I got my Spyderco R2 was a factory sharpened Native, which can push cut newsprint about 1.5" from where you hold it. At the time the best I could do was about 3/4" from where I hold the newsprint, but since I bought a 60-100 power lighted microscope from Radioshack and minimized my burrs I can now get knives close to that Native with the white sharpmaker stones. I thought that was about as sharp as you can get a knife. But my new R2 can pushcut newsprint over 3" (just under a full blade length) from where I hold the newsprint, and this is by far the sharpest knife I have ever used. It also has excellent slicing aggression. The grind is a thin flat grind, and the edge is very thin and around 10 degrees. I will put some calipers on it later to see how thin it is. I guess this knife shows me I have a long way to go in my sharpening technique to get truly sharp knives.
Cliff Stamp said:Depends on the hair and exactly what you mean. If you are serious about sharpness you want to move to a definate test. The easiest one to use in a quantitative way is to push cut newsprint. There are several ways to do it. I pinch the sheet of newsprint between my fingers and the further away from that point you can push the blade into the paper, the sharper the knife. With a really sharp knife you can get out to 3+ inches.
-Cliff
