Cliff Stamp
BANNED
- Oct 5, 1998
FlyingMuskrat said:So how sharp would you call a knife that can push cut straight down through newspring very close to where you hold it?
A few years back I would have called it sharp, now I would call it burred, unless your newsprint is very different than mind. With optimally sharpened edges you can move out to a few inches. It also depends on how you cut it. Rotate the page 90 degrees and try push cutting. It will either get much harder or much easier as there is a grain to the paper.
In regards to the reprofiling, the primary grind was changed from low sabre flat to higher sabre/convex. The secondary edge bevel was mainly obliterated. I'd call it a reprofile of the primary grind.
-Cliff
